Tailscale Mesh VPN
G4GUO
Tailscale Mesh VPN
Post by G4GUO » Mon Nov 24, 2025 9:33 am
I have just started using https://tailscale.com/
It allows you to setup a secure virtual network across the internet, so for example, you can access your local LAN from a remote device.
For 3 users it is free. It might be useful when out portable or away from home.
Anyone else using it?
- Charles
g8lce
Re: Tailscale Mesh VPN
Post by g8lce » Tue Nov 25, 2025 9:16 am
Yes, I have. It has had quite a few updates since I started using it. I don't know where it is based and have not looked. Another thing I have done is setup a TinyGS station which is similar to the RSGB balloon experiment. It picks up low earth satellite data. When I looked at the RX data it was mainly Russian, Chinese and Iranian satellites! However, when I checked I found it is run from Spain and I am happy.
https://tinygs.com/station/G8LCE@cbjkMXaUWEdfbJTi
I am going to switch it to just receive the LightSail cubesat that will be launched from the ISS on 2nd December.
https://alphacubesat.cornell.edu/dashboard.html
There is a thought that radio amateurs should look at these data services more. We could (and some are) setup our own 'Internet' using radio. We already use radio for high speed data through repeaters and satellites although we call it DATV.
iGate, TinyGS and DATV
G4GUO
Post by G4GUO » Tue Nov 25, 2025 10:36 am
I watched an interview with the U.S founder of Tailscale, he was trying to build a service that people could use rather than make billions which mean't
he had difficulties raising money, as he wasn't being ambitious enough. The guy that does most of the Tailscale videos is British (judging by his accent).
I have a TinyGS node here as well, but I am not sure if it is still running, as it is located in a shed in the garden that I seldom visit. I also supply an ADSB feed to fligh24 using a spare PI, that gets me access to their paid network.
I set up a Meshtastic node, again I have not checked recently whether it is still running.
I contribute weather data to the Met Office WOW system https://wow.metoffice.gov.uk/ (search on there for 'Ferring Beach')
I have also looked at selling GPS information or renting out my GPUs, but even with solar it doesn't look worth doing, plus my internet connection
is so slow that I wouldn't qualify for GPU sharing project.
It was sad when the packet radio development ground to a halt, mainly due to the lack of development of higher speed modems, dumb routing algorithms and the internet.
- Charles
g8lce
Post by g8lce » Tue Nov 25, 2025 1:40 pm
I am using Tailscale at the moment to write this on my home computer while actually several miles away. I am using my Windows laptop connected to the Internet using mobile phone as a Hotspot (the building I am in's WiFi has lost Internet connection!! ). I am using Remote Computer Connection and the IP address Tailscale has given the home computer to make it work. There is a delay sometimes but I can run vMix on my home computer remotely to transmit. Could be useful to see transmission distance etc. Worth giving it a go.
G4GUO
Post by G4GUO » Tue Nov 25, 2025 2:12 pm
Great!
I must go somewhere with free Wi-Fi and try something similar. So far, I have only simulated being remote.
At least for our types of applications, this is free to use.
My main server is based on a workstation motherboard so I can turn it on and off remotely, so I can just leave a small
low power device running while I am away and only turn on the main machine remotely when needed.
- Charles
G4GUO
Post by G4GUO » Wed Nov 26, 2025 11:16 am
I set up the Tailscale app on my pfSense router as an exit node with a subnet defined to allow local LAN access.
Then, while waiting for my dental checkup, I used the dentist's free Wi-Fi and was able to SSH into a computer on my home LAN.
So looks like I am all good to go now.
- Charles
g8lce
Post by g8lce » Thu Nov 27, 2025 9:46 am
I use a remote controlled mains plug ( via Hive in this case ) to power the Windows PC. The PC is set to start on mains power on. When the PC is on I can remotely control it. If it is off then a remote ( via Hive app ) switch off - wait 10 seconds for power to die - then switch power on again. Wait for the time it takes for the PC to come up and away I go with remote control.
Post by g0mjw » Fri Nov 28, 2025 10:30 am
- Charles
I am using openvpn - free for any number of users.
G4GUO
Post by G4GUO » Fri Nov 28, 2025 11:22 am
I am only using Tailscale as that is the one that all the tech U-tubers seem to prefer.
I just wanted a way to access my cameras / station while I am away, and Tailscale was simple to install.
I like simple :)
Having said that they are constantly adding new tools and services that I am not likely to use.
Here is their comparison of the two systems (obviously biased towards their product)
https://tailscale.com/compare/openvpn
Post by g0mjw » Fri Nov 28, 2025 11:56 am
Ex-Microsoft development team perhaps?
