analogue composite to hdmi and lock signal
G4WIM
Post by G4WIM » Fri Aug 15, 2025 6:39 am
Hi guys, yet another question.
This is one I've solved in the past but have lost the 'recipe'.
I need to convert an analogue video signal from a FM rx to HDMI and generate a lock / signal present signal.
In the past I think I used an LM1881 plus 567 PLL chip for the lock signal.
Now perhaps I should use a RPI plus a usb video dongle for the conversion and some external signal detection for the lock signal.
I do have a cheap composite to HDMI converter but yet to determine how well it works with a noisy signal but would still need to generate a reliable lock signal.
Any comments / ideas ?
Regards Tim
G4WIM
Re: analogue composite to hdmi and lock signal
Post by G4WIM » Thu Aug 21, 2025 8:10 pm
I rediscovered an old design I had filed away using an LM1881 and NE567 for analogue lock detect - works very nicely.
The analogue to HDMI converter only has limited tolerance for weak signals with poor sync and drops out if the picture is anything less than about a P3.
I think I'll try a BATC dongle and RPI to see if that's any better under weak signal conditions.
