Is GB3TV working?
Locator: IO91RU
M0DQW
Is GB3TV working?
Post by M0DQW » Sun Jul 20, 2025 4:08 pm
For the past few days I have not been able to receive GB3TV from Aylesbury, there is no output.
I have not tried sending an input signal, but I thought this repeater was on 24/7?
Maybe there is an issue that someone knows about?
Matt
arthur21
Re: Is GB3TV working?
Post by arthur21 » Mon Jul 21, 2025 8:35 am
Hi Matt
GB3TV is off the air at the moment, ( to much heat) A site visit is arranged for Wednesday afternoon to investigate the problem and if possible to fix it.
Arthur
G4CPE
arthur21
Post by arthur21 » Wed Jul 23, 2025 6:31 pm
GB3TV is back on air and now with a much improved 70 cms RX. No streaming at the moment but Phil is working on it.
TX o/p is on 1318.5 MHz DVBS 1ms Mpeg2
73 Arthur G4CPE
M0DQW
Post by M0DQW » Wed Jul 23, 2025 8:51 pm
70cms input does seem to be improved. Managed to get a signal in on 437MHz using the vertical tri-bander above the house.
Well done team and thankyou!
Post by g0mjw » Thu Jul 24, 2025 7:13 am
I will have to have a try. I need to receive it, I normally can.
By the way Matt, you can get some good studio lights these days. No need to sit in the dark :)
Post by g0mjw » Thu Jul 24, 2025 8:13 am
Quick test, unfortunately my 70cm TX desenses my 23cm RX terribly. So I reduced power to about 1W and
Screenshot 2025-07-24 090622.png (714.85 KiB) Viewed 3494 times
So there is certainly an improvement. I am still de-sensing myself so the return of the streamer would really help
Edit Arthur G4CPE came back, so certainly working. If I can get in with 1W to the beam I might investigate a second antenna to avoid the de-sensing.
M0DQW
Post by M0DQW » Thu Jul 24, 2025 9:08 am
I was having that issue with the desensing until I made a little 23cm high pass filter pcb. Then magically I can receive on 23cm and transmit on 70cm with no issues, and the beams are stacked together :-)
M0DQW
Post by M0DQW » Thu Jul 24, 2025 9:11 am
It was night time, I think ;-)
Post by g0mjw » Thu Jul 24, 2025 12:35 pm
But it would need to be up on the mast before the pre-amp. I have one, I might try it when I next luff the tower.
M0DQW
Post by M0DQW » Thu Jul 24, 2025 12:43 pm
I just placed it at the input of the pluto I was using to receive 23cms. works great!
Return to “GB3TV”
