Langstone V3 Update
Langstone V3 Update
Post by g4eml » Tue Jul 15, 2025 5:00 pm
Langstone V3 now also supports the new Raspberry Pi V2 display.
The installation process remains the same. The new display is automatically detected.
Note that if you are replacing the display on an existing system you will need to create a new SD card and do a clean install. The operating system doesn't seem to like the display being changed on an already configured system.
I can also confirm that although Langstone V3 was developed and tested on a Raspberry Pi 5 it does appear to run OK on the older Raspberry Pi 4.
Colin G4EML
