portsdown 4
joefran7300
portsdown 4
Post by joefran7300 » Tue Jul 01, 2025 12:29 pm
Hello To every one.
I have build the portsdown 4 and it is working ok,and i am using the composite to usb converter that i bought from the BATC shop but the picture is not very good as i am connecting my PC HDMI to an HDMI to composite converter and then i an connecting the composite to usb for the portsdown 4.
My quetion is is there any HDMI to USB that can work with the portsdown 4 that i can buy to connected from the PC to USB for the portsdown 4 please.
g6hfs
Re: portsdown 4
Post by g6hfs » Tue Jul 01, 2025 10:14 pm
Pa3fbx
Re: portsdown 4
Post by Pa3fbx » Wed Jul 02, 2025 10:28 am
If you use PC to generate the picture why not send it over IP and use TS-IP function in stead of the camera option..
Quality will improve fast..
benno
Re: portsdown 4
Post by g0mjw » Wed Jul 02, 2025 5:11 pm
Hello To every one.
If you are using a PC it would be far better to encode on that PC and use the IPTS facility as Benno indicated. No need to go via HDMI and potentially the option to use H265 rather than H264. It does require a network connection but most PCs have that and if they don't a USB dongle will do the job.
joefran7300
Re: portsdown 4
Post by joefran7300 » Fri Jul 04, 2025 9:22 am
Hi to all
Thank you for all information...the thing is that i try to use the IPTS and i am using the OBS studio and i am connecting with the portsdown4 but i have a very huge delay as when i put TX on the portsdown4 it will take long to go on air and the picture will start and then freez and the same to go back OFF....i do not know why..
73's
g8lce
Re: portsdown 4
Post by g8lce » Sat Jul 05, 2025 8:00 am
Check the data rates of your video and audio. Sometimes too much data can cause problems!
Martin G8LCE
joefran7300
Re: portsdown 4
Post by joefran7300 » Sat Jul 05, 2025 8:04 am
Hi Martin
I am new using the OBS studio so i don't konw the exact setting that i nees to stream to the Portdown 4...
73's Joe
G1BVI
Re: portsdown 4
Post by G1BVI » Sat Jul 05, 2025 9:06 am
Hi Joe (nocallsign?)
I use free streamcoder which is set up on the PC running OBS
All the hard work has been done for you in this utility.
Start OBS
Then start Free stram coder
If you have got the PD4 IP correct you can then monitor this on the PD4 screen
Nick
G1BVI
joefran7300
Re: portsdown 4
Post by joefran7300 » Sat Jul 05, 2025 10:11 am
Hi Nick
Thank you for the information i will try it and see what i can do...
many thanks
73's Joe 9H1GT
G1BVI
Re: portsdown 4
Post by G1BVI » Sat Jul 05, 2025 11:05 am
Hi joe
9H1GT
Nice thermionic collection
I sent you an email to help you on your way.
In my experience streaming OBS over a network with decent quality is quite processor intensive and may be why you are having problems.
Running this French utility F1EJP takes credit hopefully will show you if your hardware is up to the job
Nick
