Pico Tuner Rpi Pico Programming
G1BVI
Post by G1BVI » Tue Jun 17, 2025 5:39 pm
Hi All
The instructions are clear at https://wiki.batc.org.uk/Surface_mount_ ... ner_V2_PCB
Download the uf2 file.
Plug in the stand alone Rpi pico and copy the file to it.
It loads but DOES NOT reboot as described.
It does however show in device manager in Win 11 under other devices as
BATC picoTuner i2c
BATC PicoTuner TS
Both have an explanation mark as there are no drivers for the board and also the Rpi Pico is no longer seen as an USB device.
Tried 2 boards direct from Pi Hut before going near a soldering iron and clearly there is a problem.
What drivers are missing on the Win 11 m/c in order that these boards are recognised or is this normal with the latest uf2 (v 0.12)
TIA
Nick
G1BVI
Re: Pico Tuner Rpi Pico Programming
Post by G1BVI » Tue Jun 17, 2025 6:50 pm
Answering my own question..
Go to
https://zadig.akeo.ie/
Download Zadig 2.9 (Current version and the drivers for yje TS and i2c can be installed
Nick
Post by g0mjw » Tue Jun 17, 2025 6:55 pm
Suspect you broke your system with Zadig and then fixed it again.
Post by g4eml » Tue Jun 17, 2025 8:10 pm
The instructions for loading the drivers on Windows are included in the GitHub readme document.
https://github.com/g4eml/PicoTuner#usb-drivers.
Colin G4EML
G1BVI
Post by G1BVI » Wed Jun 18, 2025 7:14 am
Tanks Colin
I was following the BATC wiki
Next get down to the soldering
Nick
