Wanted: 70cm DATV amplifier
If you are looking for something, ask here
Adverts will be archived when the poster indicates that the item is found or after one year. If you wish to keep advertising after one year, please re-post.
M0DQW
Post by M0DQW » Wed Apr 09, 2025 10:22 pm
Looking for a 70cm DATV amplifier, for 437MHz.
Thank you.
Matt
M0DQW
Re: Wanted: 70cm DATV amplifier
Post by radiogareth » Thu Apr 10, 2025 7:24 am
Pallet to build up or a turn-key solution?
G8IKP
Post by G8IKP » Thu Apr 10, 2025 8:10 am
Jim G7NTG has some 300w pallets at a reasonable price, just bought two myself.
John G8IKP
M0DQW
Post by M0DQW » Thu Apr 10, 2025 8:48 am
Hi all..
I do not mind if its a pallet or ready build tbh.
I did try emailing Jim but no response, maybe I have an old email address that he no longer uses.
Matt
Post by g0mjw » Thu Apr 10, 2025 8:58 am
Hi Matt
It depends what you want in power terms. There are several options, from Aliexpress to a pallet you might need to modify. Jim imported several of the PAs you may have seen me talking about, they are good for 100W of DATV, and a lot more SSB/CW. Mods are in CQTV 286.
I have tried to email you but I don't know if your QRZ email is up to date. Jim's is OK in QRZ as far as I can tell.
M0DQW
Post by M0DQW » Thu Apr 10, 2025 9:05 am
Thanks Mike!
I received your email, thank you. And yep, I resent my email to his QRZ email address so hopefully get a reply.
To be honest, I just need enough power to reach GB3TV 437 input from here. I have tried a couple of these Chinese 25 watt amps, but they distort the signal if I push them too hard, i.e massive shoulders!
Although, if I had more power than needed, I could always experiment with others on 437.
Hopefully Jim will reply and I will see what he has available and if its cost effective for my needs.
Cheers :-)
Matt
Post by g0mjw » Thu Apr 10, 2025 9:39 am
Hang on - so the GB3TV 70cm input is working now? I will have to try.
M0DQW
Post by M0DQW » Thu Apr 10, 2025 9:55 am
Apparently so. I have had zero success on 437 so far. However, G4IYT tested it yesterday from Leighton Buzzard and he was able to get in on 20 watts.
M0DQW
Post by M0DQW » Thu Apr 10, 2025 12:50 pm
Mike, Just spoke to someone and they told me there will be a new 70cm lna and filter added soon. Apparently its currently extremely deaf on 70cm.
M0DQW
Post by M0DQW » Mon Apr 14, 2025 9:10 pm
To confirm, I am now sorted for an amplifier thanks to Jim.
Thank you everyone that commented and advised.
Matt
Return to “Wanted”
