How to daily reboot
PE5PVB
How to daily reboot
Post by PE5PVB » Mon Jan 06, 2025 10:18 am
The Winterhill at our repeater site sometimes jumps to "timeout" on all inputs or the receiver just stops. Manual restart works fine, but is not a good solution.
Can someone explain me how to plan a daily reboot of the Winterhill at 0.00h and 12.00h?
Re: How to daily reboot
Post by g0mjw » Mon Jan 06, 2025 3:52 pm
As it is running on linux, a suitable file in /etc/cron.daily to reboot the pi might be a solution, but that relies on the system not crashing. Personally, I use a mechanical mains timer, the ones designed to turn the lights on and off when you are not at home, they tend to work.
For info on cron https://en.wikipedia.org/wiki/Cron
What you really need to do is monitor and detect the timeouts and restart the winterhill application rather than reboot the machine.
PE5PVB
Post by PE5PVB » Mon Jan 06, 2025 4:08 pm
For that I need a piece of software which monitors the function of Winterhill and if not OK reboot the application.
Post by g0mjw » Mon Jan 06, 2025 4:50 pm
Yes, that's what I was suggesting you develop, bash or shell script perhaps? One that checks for a lockup and acts accordingly. The question is how do you know it has locked up. Is there some indicator? It will only work if you have a way to tell it has locked up, e.g. a process is no longer running or no data etc. I don't know if you can do this via the winterhill api. I would think so.
For a daily reboot at say 23:59, add this to crontab -
Type sudo crontab -e // That opens the editor
then add a line
59 23 * * * /sbin/shutdown -r now
Save it.
PE5PVB
Post by PE5PVB » Tue Jan 07, 2025 9:51 pm
Done that, but it doesn't work. When checking uptime it says over 4 days. So that was the last time I manually rebooted it.
Do I have to enable CRON somewhere?
then add a line
Save it.
DL5BCA
Post by DL5BCA » Sat Mar 08, 2025 10:44 am
restarting the Raspberry hard is not a good idea.
First the program winterhill should be closed.
I shut down my Winterhill with these commands:
ssh pi@192.168.178.57 sudo /home/pi/winterhill/whstop-3v20.sh ; timeout 10 ; sudo shutdown now
The IP-Adress is the adress of the winterhill-raspberry.
The "shutdown" command can certainly be changed to a reboot - but I haven't done that yet.
Put this commands in a "stop.bat" textfile and call it with cronetab
i hope it helps.
73 Thomas DL5BCA
I always have crazy ideas.
Please don't be surprised.
PE5PVB
Post by PE5PVB » Sat Mar 08, 2025 10:54 am
I have the problem that Winterhill jumps to time-out on all inputs a few times a day. Any fix would be Great.
Post by g0mjw » Sat Mar 08, 2025 12:39 pm
Thomas has provided a solution right above your post. Did you not understand how to implement that? It is crontab, not cronetab. Google should throw up examples - e.g. the top hit was https://bc-robotics.com/tutorials/setti ... pberry-pi/
Edit: I have a similar problem with my home router locking up after a few days, I think it knows when I am away from home so choses to do it then when I can't easily reset it. With no firmware fix likely, I reboot it at 2am via a time switch. Sometimes the older methods are the most reliable. However, I realise now you said several times a day which implies something is wrong, like a memory leak or buffer over run. If that's bug can't be found, or until it is found, probably best to reboot it as suggested above, from another PI that is keeping a watch on the situation.
Post by G4EWJ » Sat Mar 08, 2025 8:46 pm
PE5PVB, remind me how you are using WH. Are you sending the TS off your local network from a repeater?
Do you have the OFFNET_TIME in winterhill.ini set to a large value like 2 billion, to prevent the timeout?
I'm sure I've had this conversation before, but I cannot remember with whom.
PE5PVB
Post by PE5PVB » Sat Mar 08, 2025 9:08 pm
Yes I send the streams on LAN to our playout PC
