Portsdown4 and « C920 pro »
f5iwn
Post by f5iwn » Sat Dec 28, 2024 7:56 pm
Hi all,
Regarding the webcams supported by Portsdown 4, it’s specified: « The Portsdown 4 works with all (3) versions of the C920 »
Do these three versions include the « C920 pro » which available at some retailers ? If not, does someone know the status for this « pro » version ?
In advance thank you !!!
Best 73s
Christophe F5IWN
Re: Portsdown4 and « C920 pro »
Post by G8GKQ » Sun Dec 29, 2024 12:36 pm
Hi Christophe
Support for C920 webcams is discussed on this Wiki Page: https://wiki.batc.org.uk/Portsdown_Vide ... ld_Version
To determine whether the C920 pro is supported, you would need to run the command "lsusb" and check the camera's response aganst the 3 supported versions.
If it is a (4th) different version, I would need listings of the responses to lsusb and the 4 other commands listed at the top of that Wiki page to determine whether support could be added.
f5iwn
Post by f5iwn » Mon Dec 30, 2024 10:55 am
Thank you for your answer !!
I have no supported Webcam so far (or to be honest I lost a C920 or C930 somewhere in my mess ;-) ) , so I need to purchase one ... I dug a little bit more on all the discussions around the C920 ... it seems that many versions exist ... complex ....
So I think I will start with a C170 ... as it seems that only one version exists, right ? so this is more safe/deterministic .. then at beginning I target only low SR so I don't need absolutely a "high end" camera !
Best 73s
Christophe F5IWN
i2NDT
Post by i2NDT » Mon Dec 30, 2024 5:43 pm
Hi Christophe,
may I suggest you buy a PiCam? the old model which I guess is still avalable. it's cheaper than a C170 or 920 and allows you to watch on the screen, during transmission, the image you send while with the webcam, as far as I know, it's not possible...
consider that the PiCam is maybe more complicated to handle...as it is connected to the RasPi with a flat ribbon cable, so not so easy to move around!
best 73 and a Happy New Year!
de
i2NDT Claudio
i2NDT Claudio
Dalmine, Italia
f5iwn
Post by f5iwn » Tue Dec 31, 2024 7:34 am
Hi Claudio,
Yes you are right the Picam is a good choice and I already have one !
But as you mentioned, the way this cam is connected is quite complex to handle and at the end the set-up is not so robust , this is why I am looking for an alternate solution !
That being said, a picam can be mechanically integrated in the box hosting the screen and could become a robust set-up ... to be investigated as well !
Anyway thank you all for your feed-backs and advice !
Best 73s
Christophe F5IWN
f5iwn
Post by f5iwn » Fri Jan 03, 2025 8:07 pm
I finally purchased a C920 named "C920 PRO HD Webcam" ... the one available at Amazon
So I share the result with you (it could be helpful for someone):
- It works , clearly visible using the C920 monitor
- the lsbub commands gives : "Bus 001 Device 003: ID 046d:08e5 Logitech, Inc." => So the third type which us mentioned here https://wiki.batc.org.uk/Portsdown_Webc ... itech_C920
- the webcam related information in the info menu of Menu 2 indicates: "new with no H264"
Everything seems to be ok => Next step a local transmission test
Thank you for this helpful discussion
Best 73's
Christophe F5IWN
DD7PC
Post by DD7PC » Thu Oct 09, 2025 4:12 am
Hello Christope (F5IWN),
is there a way i can contact you regarding a question about your QRP DATV tests you described in Bulletin Hyper Sept. 2025?
merci, vy73
Marco
DD7PC
mailto:dd7pc@gmx.de
