Default status screen colours
Post by G3GJA » Sat Dec 28, 2024 12:19 pm
Tim
Is it possible to globally change the colours of the status screens?
The black on red has a low contrast range because the luminance component varies between 0% and 30%.
On GB3EY I'd like to be able to change them to yellow text on a blue background. That would give luminance values of 89% and 11%, a range of 78% which is more than double the contrast.
I have tried myself, but only succeeded in making a mess of it!
Clive G3GJA
g8lce
Re: Default status screen colours
Post by g8lce » Sun Dec 29, 2024 10:31 am
See
viewtopic.php?t=7024
and a PDF of the info:
Editing Ryde Screen.pdf
(145.72 KiB) Downloaded 486 times
Martin G8LCE
Post by G3GJA » Sun Dec 29, 2024 11:16 am
Thanks for the reference Martin.
I've got as far as changing the background successfully, but it's the text colour I was having difficulty with.
Did you ever manage to change it from black? I changed the status screen text but it messed up the station ID that pops up briefly (with the blue borders and white background).
Clive
MW0RUD
Post by MW0RUD » Sun Dec 29, 2024 3:22 pm
Hi Clive
Have a look in rydeplayer/states/playback.py
The line below is the one where the text is rendered and pulls the colour out of the theme.
lineSurface=self.theme.fonts.playStateTitle.render(line, True, self.theme.colours.black)
Tim
Post by G3GJA » Sun Dec 29, 2024 4:33 pm
Hi Tim
Do I need to define the colour yellow first? Perhaps in the player.py section:
# container for the theme
class Theme(object):
    def __init__(self, displaySize, ftfont=False):
        self.colours = type('colours', (object,), {
            'transparent': (0,0,0,0),
            'transpBack': (0,0,0,51),
            'black': (0,0,0,255),
            'white': (255,255,255,255),
            'red': (255,0,0,255),
            'textError': (255,0,0,255),
            'menuBlackInactive': (0,0,0,127),
            'backgroundMenu': (57,169,251,255),
            'backgroundSubMenu': (57,169,251,255),
            'backgroundPlayState': (0,0,255,255),
Clive
Post by G3GJA » Sun Dec 29, 2024 4:56 pm
Thanks for putting me on the right track, Tim.
I've answered my query about defining the colour in player.py by modifying it and now I've yellow text on a blue background.
Clive G3GJA
