A worldwide first?
HB9DUG
A worldwide first?
Post by HB9DUG » Sun Dec 01, 2024 4:49 pm
DATV linear transponder on HB9TV-1 relay
For those interested, full details at
https://home.swissatv.ch/2024/12/une-premiere-mondiale/
73 de michel, hb9dug
Re: A worldwide first?
Post by M0DTS » Mon Dec 02, 2024 11:46 am
Very interesting Michel, i have wanted to do this for a long time but never got round to it!
Well done and i will keep an eye on the websdr!
Post by g8gtz » Mon Dec 02, 2024 12:12 pm
Hi Michel
Very interesting - any chance of a short CQ-TV article?
HB9DUG
Post by HB9DUG » Tue Dec 03, 2024 3:01 pm
With pleasure Noel !
vy 73 de michel, hb9dug
SkyVision
Post by SkyVision » Wed Dec 04, 2024 5:30 am
Could someone please expand this a bit
Is this a repeater where the input is not decoded and then re-encoded
And the transport is passed from the Rx to the Tx, which may regenerate the signal
Or some form of translator/transmodulator where it exits at different parameters/mode
Bent pipe?
Cheers Roger VK5YYY
Post by g0mjw » Wed Dec 04, 2024 9:04 am
I am assuming it is a linear transponder, like on QO100, but mounted on a mast on a mountain, rather than in space. In a sense that is nothing new, we have had TV relays for many decades, but new in the amateur arena. Actually I do remember there was something similar tested for CW/SSB in the past.
I experimented with something similar using an Ettus B200 and Gnuradio around 12 years ago. As I recall, the main problem was the AGC and preventing strong signals on the input driving the output too hard, while retaining sensitivity.
The near-far effect, coupled with terrain losses, can represent signal strength differences of many orders of magnitude at VHF/UHF. While the same issue applies to the QO100 satellite transponder, it is not anywhere near as extreme as terrestrially because all ground stations are at similar ranges, and line of sight, so it is only the difference in transmit power and antenna gain. I am interested in how Michael has solved that challenge.
HB9DUG
Post by HB9DUG » Fri Feb 28, 2025 12:09 pm
I have added a page on the HB9TV.ch documenting the new transponder module including measures done by Pierre HB9IAM, here:
https://hb9tv.ch/lhistoire/hb9tv-1-transpondeur/
73 qro de michel, hb9dug
