PicoTuneWH - firmware for the PicoTuner with a Pico Ethernet module.
Post by G4EWJ » Fri Aug 16, 2024 10:40 am
The latest beta version is available on the BATC Wiki: https://wiki.batc.org.uk/PicoTuner_Ethernet_Interface
Download the firmware from section 2, Updates, News and Issues: https://wiki.batc.org.uk/PicoTuner_Ethe ... and_Issues
Please post any questions or problems here.
Re: PicoTuneWH - firmware for the PicoTuner with a Pico Ethernet module.
Post by g0mjw » Tue Aug 20, 2024 3:16 pm
I have swapped out my Winterhill for a Picotuner. Apart from initially not working because still had the link in for the higher port number, it is working fine. At least so far, with one exception. I can't seem to make it switch to 13V with Rob's QuickTune. It stays set to 18V. Not sure what I am doing wrong.
So, a question arises, the whpcviewer app has 4 or 9 screens - it would be nice to have an option for two.
Edit - I should add why 13V matters. I am using one LNB for narrow and and wideband and powering it with the picotuner. I need 13V for narrow band.
Post by G4EWJ » Tue Aug 20, 2024 4:15 pm
I see the problem with the QuickTune voltage setting. I'll release an update shortly.
I'll put the 2 screen viewer on the list.
Post by G4EWJ » Tue Aug 20, 2024 4:33 pm
Version ptwh0v3c has a problem with applying QuickTune LNB voltage settings. Version ptwh0v3e corrects the problem.
Post by g0mjw » Wed Aug 21, 2024 6:04 pm
It sort of fixes it, but not quite. It seems to only follow what is set for RX1. If you set RX2 to 13V, then nothing happens, it stays on 18V. At least that's what it seems to be doing in my case.
Post by G4EWJ » Wed Aug 21, 2024 8:09 pm
I tested the fix on RX2 and it seemed to do the correct thing. Can you look at the broadcast packet on port 9997 and see what that is indicating for the VGX status. It doesn't guarantee that the pins are in the correct state, but it might give some info.
Post by g0mjw » Wed Aug 21, 2024 8:16 pm
Can you remind me how to look at the port ?
Post by G4EWJ » Wed Aug 21, 2024 8:23 pm
Easy on an RPi, less so on a PC.
https://wiki.batc.org.uk/PicoTuner_Ethe ... _Port_9997
Post by G4EWJ » Thu Sep 26, 2024 2:40 pm
Use netcat -kluv 9997 to view the broadcast packet on an RPi. netcat -kluvw 0 9997 tends to wind up a processor to maximum.
SQ6EMM
Post by SQ6EMM » Thu Nov 28, 2024 10:43 am
Hey I have a problem with the firmware it asks DHCP server for an IP but it does not accept it..
ptwh0v3e-w5100s.uf2 is starting
PicoTuner Dual Channel Digital TV Receiver - WinterHill mode - Version=ptwh0v3e-w5100s.uf2
+++ NIM_A FTS4334L initialised +++
Waiting for Ethernet link - 0
Waiting for Ethernet link - 1
DHCP: starting
DHCP: DISCOVER sent - My MAC 28:CD:C1:86:6E:38 - Transaction ID 2DCF6E38
DHCP: waiting for OFFER
DHCP: timeout - waiting to retry
DHCP: DISCOVER sent - My MAC 28:CD:C1:86:6E:38 - Transaction ID 46296E38
DHCP: OFFER of 192.168.12.131 received from 192.168.12.1
DHCP: REQUEST sent
DHCP: waiting for ACK
DHCP: NAK received ()
DHCP: --- FAILURE ---
DHCP: waiting to retry
DHCP: DISCOVER sent - My MAC 28:CD:C1:86:6E:38 - Transaction ID 04B46E38
DHCP: REQUEST sent
DHCP: DISCOVER sent - My MAC 28:CD:C1:86:6E:38 - Transaction ID 78D86E38
DHCP: REQUEST sent
DHCP: DISCOVER sent - My MAC 28:CD:C1:86:6E:38 - Transaction ID 68A76E38
Any idea?
