Pico Tuner - LNB Voltage? (RESOLVED)
G1INU
Post by G1INU » Thu Jun 20, 2024 5:03 pm
I will put this here as we don't appear to have an area dedicated to Pico Tuner's.
Brand new build;
Pi4, 7in screen, running Portsdown 4.
Pico Tuner V3 Board
Pico Board V0-11 Fw.
JP3 is shunted to put LNB power to the bottom port.
Port B is selected in Portsdown 4.
I have eternal power to the Pico Tuner and a usb cable from Portsdown to the pico board mini usb.
Red power LED is on on the V3 Board and the green led is flashing on the pico board, which if I am understanding forum threads is correct.
Test voltages on the test points are correct except (I believe) TP 1 which is only showing 0.24v when 13v is selected in Portsdown4, and 3.6v when 18v is selected in Portsdown 4.
LED 3 is not illuminating to suggest a fault on U1.
I have no idea if this going to be a hardware or software issue so Any suggestions on where to start will be most welcome.
Thanks.
Regards
Mark - G1INU
Re: Pico Tuner - LNB Voltage?
Post by g0mjw » Thu Jun 20, 2024 5:45 pm
Perhaps post a photo of the area around the LNB supply?
This is the datasheet for the LNB supply - you can test a few things by checking voltages on the pins
https://www.richtek.com/assets/product_ ... 47A-00.pdf
The pins on the right hand side are the control signals. Pin 4 is the input voltage - should be 12V or so that you are putting in. The ground is the tab on the bottom you soldered through from the back.
So, what do you measure on each pin?
Screenshot 2024-06-20 185130.png (19.72 KiB) Viewed 5191 times
Screenshot 2024-06-20 185104.png (97.08 KiB) Viewed 5191 times
G1INU
Post by G1INU » Thu Jun 20, 2024 7:23 pm
All pin voltages test with Portsdown 4 in standby and then with it in Receive mode on screen (Both read the same) and LNB Volts set to 13 Vert
1 : 0.6v
2 :12.25v
3 :12.39v
4 :12.39v
5 : 3.2v
6 0v
7 : 2.44v
8 : 0.89v
When I change LNB Volts to 18 Horiz pins 1 6 7 and 8 increase. Obviously 6 is switching it from low to high. Its just that its not getting the voltage expected at pin 1,
1 : 3.28v
2 :12.25v
3 :12.39v
4 :12.39v
5 : 3.2v
6 : 3.2v
7 : 3.99v
8 : 3.57v
Regards
Mark - G1INU
Post by g0mjw » Thu Jun 20, 2024 8:09 pm
Could you do a photo? Perhaps a diode is the wrong way round.
G1INU
Post by G1INU » Thu Jun 20, 2024 8:22 pm
[/quote]
Ignore, uploaded in next message
Regards
Mark - G1INU
Post by g0mjw » Thu Jun 20, 2024 8:31 pm
Under the text entry, there is an attachments tab. Upload them there.
G1INU
Post by G1INU » Thu Jun 20, 2024 8:48 pm
Regards
Mark - G1INU
G1INU
Post by G1INU » Thu Jun 20, 2024 9:33 pm
The last 2 were taken during the build yesterday hence why the solder through hole had not been completed.
Regards
Mark - G1INU
Post by g0mjw » Fri Jun 21, 2024 11:24 am
Good photos - can you take a close look at this - are all the diodes the right way round?
Screenshot 2024-06-21 122251.png (715.33 KiB) Viewed 4854 times
G1INU
Post by G1INU » Fri Jun 21, 2024 1:43 pm
Hi Michael,
Yes it's strangely difficult to get a good photo showing the orientation of the diodes but they are all correct way round, with the cathode to the PCB and the anode at the top.
Regards
Mark - G1INU
