External LNB
M1ASR
External LNB
Post by M1ASR » Sun May 12, 2024 1:47 pm
Good Afternoon
I have 2 Minitiouners and a Ryde on each, one for terrestrial and 1 for satellite and they both work fine. I want to add a satellite to my second MiniTioune for a second RX dish. Unfortunately, the second MT has no voltage o/p so I need to use an external Bias-Tee to feed 12v to the LNB. I have done this and checked for volts on the bias tee output and all fine there. However, I am not seeing a signal on the Ryde.
1. I have checked the MT voltage links and they are removed.
2. I have checked the dish signal on MT No1 and MER is 9.5 on the beacon.
3. I have checked both Tuner inputs on the MT and results the same, both work fine on terrestrial.
Before I start getting out my test gear, is there something obvious I'm missing.
Ultimately I would like to use 1 MT input for terrestrial and the other for satellite (will set this up on the Ryde).
Thank you in advance for your comments.
Re: External LNB
Post by g0mjw » Sun May 12, 2024 3:14 pm
The obvious being requiring 18V for the DATV polarisation ? No, that's too simple.
M1ASR
Re: External LNB
Post by M1ASR » Sun May 12, 2024 6:12 pm
Hi Mike,
No I have a switchable 12/18v H/V switch. I’ve swapped the bias tee and all OK now.
Regards
73, Graham M1ASR
