Pico Tuner REV 3 board ?
User guides, discussions and problem reports for the new BATC Website
bobbyni+
Post by bobbyni+ » Thu May 02, 2024 11:06 am
HI
While checking for the Pico Tuner parts list , I noticed a PICO TUNER REV 3 board layout. Any idea when these will be available in BATC SHOP.
regards Robert GI6IVJ
Re: Pico Tuner REV 3 board ?
Post by g0mjw » Thu May 02, 2024 11:21 am
There were some in stock last week.
Pa3fbx
Post by Pa3fbx » Sat May 11, 2024 8:44 am
Due to the minor updates of the rev 1 to 3. old stock will be used before new stock will be shipped out.
There are no old stock in the UK but still a few rev1 boards left in EU.
Benno
G1INU
Post by G1INU » Thu Jun 06, 2024 7:50 pm
As a newcomer to DATV I am confused.
I ordered a "PicoTuner version 3 blank PCB" on Monday (not arrived yet) and the photo alongside that heading on the BATC Shop shows Rev1 with no mention of a Rev3?
I have also used a BOM file to order all the parts from DigiKey (they have arrived), I now see that the BOM says it is for "Rev 3"?
Have I ordered the wrong list of parts for a board I haven't yet received?
Mark
Regards
Mark - G1INU
Pa3fbx
Post by Pa3fbx » Mon Jun 10, 2024 10:11 am
All rev 1 boards gone. Only Rev3 boards are in stock both in UK and in EU warehouses.
Despite the very minor differences are there no problems anymore..
Benno
F5LCT
Post by F5LCT » Sun Jun 16, 2024 9:07 am
Bonjour
I am soldering the components according to your list, quick question which model should I use as a socket to fix the FUSE AUTOMOTIVE 2A 32VDC BLADE the model is not in your list
thanks in advance
Hubert
Post by g0mjw » Sun Jun 16, 2024 5:32 pm
Mark
Not much difference. Some layout changes and addition of a power LED. Part numbers have changed but not values so should be obvious if you have the Rev1 BOM parts and a REV3 PCB. I asked for 10 Rev1 PCBs to test but rather more were ordered. They have all gone now so stick with REV3.
Post by g0mjw » Sun Jun 16, 2024 5:50 pm
Bonjour
thanks in advance
Hubert
It is a Multicomp MCCQ-122 but digikey don't do it so it is not in the Digikey BOM. It was in the Farnell BOM but that has been dropped as many of the other parts are not or are but US stock so expensive to order. However a quick google search should find a source. They are readily available on Ebay and Amazon.
The alternative, BK-6013-ND might work. I have not tried it.
This raises a point. Parts regularly appear and disappear from suppliers. Producing a project is a nightmare with parts availability. We expect builders to notice when things are no longer available and ideally propose updates to the BOM. It is a club and not a business so relies on user input.
F5LCT
Post by F5LCT » Mon Jun 17, 2024 6:07 am
Hello Mike
Thank you for your response with the name of the part, it’s simpler for me.I looked at Farnel and they have the part MULTICOMP PRO MCCQ-122, according to their website they have 160,518 in stock. and -1 my order hihi.
regards and thank's for your help
Hubert
F5LCT
g6hfs
Post by g6hfs » Mon Jun 17, 2024 3:08 pm
Yes Digikey do them, they have over 233,000 of them in stock.
https://www.digikey.co.uk/en/products/d ... IBEQBdAXyA
36-3544-2-ND
Return to “New BATC WebSite and Online Shop”
