Sending an output stream to the Portsdown for TX
G8XPZ
Post by G8XPZ » Thu Apr 25, 2024 5:12 pm
I am trying to send a stream output from my computer using either vmix or obs to my portsdown to then transmit it. I have managed to get as far as external output from vmix and then understand that vmix needs to be used to stream it. ( is that udp it?) - then it starts to become a little grey in my understanding.
Can anyone point me to an article that explains it or what I need to do please?
Steve
G8XPZ
Re: Sending an output stream to the Portsdown for TX
Post by G8GKQ » Thu Apr 25, 2024 6:33 pm
Hi Steve
Hopefully it is all on the Wiki: https://wiki.batc.org.uk/IPTS_Input_to_ ... he_LimeSDR
G8XPZ
Post by G8XPZ » Fri Apr 26, 2024 9:28 am
Thanks Dave - I have been to the article and tried the batch file in the past but struggled to get it working. I'll print the article and follow it one stage at a time and see how I get on.
many thanks
Steve G8XPZ
Post by G3GJA » Fri Apr 26, 2024 10:16 am
Steve
If you want to try an OBS solution that doesn't need batch files look here: https://wiki.batc.org.uk/OBS_-_Open_Broadcast_Studio
Works with a Lime or Pluto connected to a Portsdown.
The step by step instructions have been used twice successfully that I know of.
Clive G3GJA
Return to “Getting Started?”
