lnb supply voltage
g6hfs
lnb supply voltage
Post by g6hfs » Wed Mar 27, 2024 4:09 pm
Does the OpenTuner software/pi pico support lnb power control for the 13v/18v enable, as I can not get it to supply with on board voltage chip.
Re: lnb supply voltage
Post by g0mjw » Thu Mar 28, 2024 8:07 am
I don't know about OpenTuner, I have not tested it yet, but it works with Brian's Winterhill like firmware.
Post by g4eml » Thu Mar 28, 2024 3:53 pm
I have just checked and it appears that OpenTuner does not currently control the LNB supply.
The Pico hardware does support this and it does work with Portsdown and Ryde.
Colin G4EML
g1oar
Post by g1oar » Thu Mar 28, 2024 6:10 pm
I use Rob's Quick Tune to power on the LNB supply when using Winterhill with Open Tuner
zr6tg
Post by zr6tg » Tue Apr 09, 2024 8:00 am
The test version I sent you should work for you now ?
LNB Control pins for LNB-A on PicoTuner are Pin 9 = Enable LNB and Pin 12 = Select Horizontal
LNB Control pins for LNB-B on PicoTuner are Pin 10 = Enable LNB and Pin 11 = Select Horizontal
g6hfs
Post by g6hfs » Tue Apr 09, 2024 8:17 am
Hi Tom,
Yes, can confirm all working h and v bias volts,
Cheers
ON7TU
Post by ON7TU » Tue Apr 09, 2024 12:47 pm
Hi Tom, is it possible to sent me this adapted version for LNB power supply please?
Email: lucien.brouckaert@gmail.com
Thanks in advance,
ON7TU- Lucien
