Ryde will not lock 125Ks or 66Ks
ON5KR
Post by ON5KR » Tue Mar 26, 2024 9:16 pm
Dear
The Ryde i made will not lock 125Ks or 66Ks ? Not even in 20secs. All the rest ok.
Any ideas ?
73 Kenneth ON5KR
Re: Ryde will not lock 125Ks or 66Ks
Post by g0mjw » Tue Mar 26, 2024 9:21 pm
Probably the frequency offset.
ON5KR
Post by ON5KR » Tue Mar 26, 2024 10:41 pm
I was als thinking this way, but is it ajustable in the Ryde?
I see it locking 20dbm mer, then it drops. Very stange.
Also tried avoiding HDMI port.
Also tried port A and B.
ON5KR
Post by ON5KR » Wed Mar 27, 2024 7:59 am
I've been playing with lo settings and succes !
Post by radiogareth » Wed Mar 27, 2024 10:21 am
It produces some strange results - I have a C band LNB that is 280kHz low - that produced similar results, - lock but no picture. I have now written the 'offset' on the LNB...
Glad its working....
Basil
Post by Basil » Wed Mar 27, 2024 10:28 am
I have my Pluto and LNB both locked to a dual output Leo Bodnar. I have great difficulties receiving 66 and 33 Ks signals that others receive without issues.
I have been told it may be phase noise in the LNB, from the Bodnar mods, but could it also perhaps be due to offset, I can't work out if offset trim is applicable to a GPS locked LNB / Pluto...? Thanks.
Chris 2E0ILY.
Best regards,
ON5KR
Post by ON5KR » Wed Mar 27, 2024 10:39 am
My problem was not lnb related but straight 436MHz on Yagi.
Just for info.
73 ON5KR Kenneth
Basil
Post by Basil » Wed Mar 27, 2024 12:02 pm
Thanks Kenneth, perhaps I should have started a new topic, if the mods see fit please move my question to a new heading. I did realise your issue was not LNB related, and I am pleased you are sorting it.
Best regards,
Post by g4eml » Wed Mar 27, 2024 12:06 pm
You will still need to use the offset adjustment even with a GPS locked LNB. That is because the Tuner NIM itself is not locked and will have a frequency error. On wide signals this is not important but narrow signals need much more accurate tuning.
Colin G4EML
Basil
Post by Basil » Wed Mar 27, 2024 12:27 pm
Ahhhah! Yes, of course, the whole *chain* needs to be locked, it's obvious now, thank you Colin, I'll play with the offset next time I see a suitable signal!
33Ks is much more elusive than 66Ks, so it all starts to make sense in my old brain.... ;)
EDIT: Has anyone attempted to lock the NIM? (Seeking perfection in an imperfect world).
Best regards,
