Hi All,
I am looking for someone with a 3D printer, to print a couple of T-Beam Supreme v3 cases for me.
This looks a reasonable design.
https://www.printables.com/model/705817 ... preme-case
- Charles G4GUO
Someone to print a couple of T-Beam Supreme Cases
Re: Someone to print a couple of T-Beam Supreme Cases
Charles, there seem to be several variations in the files for different models.
If you can work out which ones you actually want, I could print them for you.
The PrusaSlicer software to view and slice the files is a free download. Default settings for a Prusa I3 MK3S and I'd suggest PLA and 0.2mm Quality as settings. Probably a 6+ hour print job depending on which parts are selected....
Hi Gareth,
I think I need the following
Alley Cat TBeam Smooth Front No Mount.stl
Alley Cat TBeam Smooth Back 10mm.stl
Button1.stl Needs 2.
Button2.stl
That, I believe is for a unit with no tripod adapter mount, and space only for the stock antenna.
Smooth I assume refers to the texture. As the job is going to take so long it might be better to only print one.
I will leave the colour up to you, but either dark/khaki or bright fluorescent orange/yellow.
It is for a portable 868 MHz Meshtastic node (the latest internet radio craze).
Button2.stl
Sorry, only just seen this....'army green' it is, 5 hours or so.
Email me you preferred delivery address....
Thanks, Gareth.
I think we can close/archive this thread now.
