Open Tuner 0.9
zr6tg
Open Tuner 0.9
Post by zr6tg » Sun Feb 11, 2024 10:26 am
Hi All,
Open Tuner 0.9 has now been released. You can find it in the usual place: https://www.zr6tg.co.za/open-tuner/
- The annoying VLC window bug should be fixed (feedback welcome)
- Ive also integrated MPV so you now have the option to select VLC/FFMPEG or MPV as video player. This binaries for MPV also includes VCC support.
- Misc other stability fixes
And then also this version contains experimental support for Colin (G4EML) PicoTuner Support. Use a Raspberry Pico to replace the FTDI Module, also includes support for dual TS (and only 1 usb cable ;)). Thanks to Colin for all the great work. More details here: https://www.zr6tg.co.za/2024/02/11/pico ... ternative/
As always, let me know if any issues.
73, Tom
G8KOE
Re: Open Tuner 0.9
Post by G8KOE » Mon Feb 12, 2024 9:26 am
Hi Tom,
0.9 working well on my system.
No problems will keep testing.
The addition of MPV makes 266 user friendly.
I had forgotten how good the Chat window is.
Thanks for all you do!
73's
Martin
G8KOE
PA3AOD
Re: Open Tuner 0.9
Post by PA3AOD » Mon Feb 12, 2024 4:28 pm
Worked well right away with the converted minitiouner.
Thanks Tom en Colin.
73,
Bert PA3AOD
Re: Open Tuner 0.9
Post by g4eml » Tue Feb 13, 2024 1:25 am
Adaptor PCBs should be available soon.
These will allow a Pico to be fitted to a V2 Minitiouner.
Colin G4EML
g8ayc
Re: Open Tuner 0.9
Post by g8ayc » Tue Feb 13, 2024 12:13 pm
That great news Colin, I'll certainly be ordering some. Thank you for the amazing work you've done on this.
OE8PCK
Re: Open Tuner 0.9
Post by OE8PCK » Tue Feb 13, 2024 3:29 pm
I am using the Open Tuner Ver. 0.9 All working OK and the screens are now stable. One small point when I close the program using the X in the corner the program does not always close but freezes and I have to go into TASK MANAGER to close the program. Not really a big problem Hi. THANK YOU very much for the wonderful software. 73 de OE8PCK Paul
g8ayc
Re: Open Tuner 0.9
Post by g8ayc » Sun Feb 18, 2024 4:32 pm
I find I can get it to close reliably if I click the X on the debug window.
Nigel G8AYC.
