Two LNB power modules.
Post by G4EWJ » Fri Feb 09, 2024 12:52 pm
Does anyone make use of both LNB power modules? I'm thinking of future designs.
Basil
Re: Two LNB power modules.
Post by Basil » Sat Feb 10, 2024 8:49 am
I am not entirely sure what modules you are referring to Brian, but my Minitiouner is in the house on a wired LAN and the LNB power sources are outside at the dish with the Pluto and PA.
I use two BATC power module boards to power the 4 port GPS locked LNB so I can watch the broadband channel at the same time as listening to SSB on the narrowband channel.
I suspect you mean the LNB power sources WITHIN the Minitiouner NIM or whatever it's called though, which in my case are not activated?
Best regards,
Post by G4EWJ » Sat Feb 10, 2024 10:33 am
Thanks. I was thinking about the 2 LNB power boards inside the WH.
I should also have asked if anyone uses the current limited 12v output.
G1LPS Terry
Post by G1LPS Terry » Sat Feb 10, 2024 3:19 pm
I use both in mine Brian.
QO-100 LNB
preamp or downconverter powering for terrestrial.
Regards
Terry
Post by g0mjw » Sat Feb 10, 2024 3:37 pm
QO-100 LNB and preamp / downconverter powering for terrestrial.
Regards
Terry
Gosh, I am surprised you have not burnt out the RFC in the tuner. They seem very fragile. Perhaps the preamp takes less current than mine does as most of it is for the coaxial relays. It shows the protection works.
Post by G4EWJ » Sat Feb 10, 2024 4:44 pm
Thanks Terry. Do you have the second PSU set to 13v?
G1LPS Terry
Post by G1LPS Terry » Sat Feb 10, 2024 5:18 pm
yes Brian
Post by G4EWJ » Sat Feb 10, 2024 5:22 pm
Thanks.
