PIC Programming
m0tvq
PIC Programming
Post by m0tvq » Fri Feb 02, 2024 11:57 pm
Wy WinterHill fails to start with a "PIC_A not found error - can't continue"
If I run the PIC programmer directly, I get output below, showing PIC_A programmed and verified but then fails the last status check.
Swapping the PIC doesn't fix the issue. If I check with the scope, the only difference seems to be a difference in the signals on SPI0 and SPI6 with SPI0 staying high, but there are no shorts on the line.
Any ideas welcome.
PIC_A:
Reading chip ID:
DeviceID=750E
Revision=0004
PIC24FJ256GA702 detected
Erasing chip:
Programming:
000000 002000 002800 002900 002A00 002B00 002C00 002D00
002E00 002F00 003000 003100 003200 003300 003400 003500
003600 003700 003800 003900 02AF00
Verifying:
*** PIC_A SUCCESS ***
PIC_B:
Reading chip ID:
DeviceID=750E
Revision=0004
Erasing chip:
Programming:
Verifying:
*** PIC_B SUCCESS ***
Checking status:
PIC_A: not programmed or version unknown
PIC_B: version 3v20
Status: 32 (0x20)
Complete
m0tvq
Re: PIC Programming
Post by m0tvq » Sun Feb 04, 2024 9:46 am
I checked this out further, and it seems to programme both PICs with the I2C address of PIC_B.
Hardware wise, the board looks ok. The only difference I can see is that SS_Y / SPI6_CEO_N on PIC_B has activity, but SS_X / SPI0_CEO_N on PIC_A always stays high during programming. No obvious use of this line in the code.
I can make it work by changing the PIC_A address in the main program to the PIC_B address, not obviously only for one PIC.
Re: PIC Programming
Post by G4EWJ » Sun Feb 04, 2024 11:11 am
I'll have a look at this as soon as I can get to my WinterHill.
Re: PIC Programming
Post by G4EWJ » Sun Feb 04, 2024 12:09 pm
Pin 24 on each PIC tells it whether to be A or B.
Check the values on the PIC pin.
Pin 24 on PIC_A should be pulled low by R31.
Pin 24 on PIC_B should be pulled high by R39.
Also check that R32 is fitted and R33 is not.
m0tvq
Re: PIC Programming
Post by m0tvq » Sun Feb 04, 2024 12:38 pm
Perfect thanks, Brian. R31 was O/C so I can understand now what was wrong as I couldn't quite follow the excellent code.
Thanks for the quick help! Stephen
Re: PIC Programming
Post by G4EWJ » Sun Feb 04, 2024 12:56 pm
Jolly good.
The NIMs receive the same signal (AS0) as the PICs to tell them which one to be, so I was puzzled as to how the NIM and the PIC could be different. As I recall, the NIMs have a weak pull down and the PICs have a weak pull up, so maybe the signal was hovering in the middle somewhere and the two devices have different thresholds.
