Latest update
g6hfs
Latest update
Post by g6hfs » Fri Jan 19, 2024 2:14 pm
Cannot find boot to tx option in latest release 202401170, do you need pluto or lime plugged in?
DL1BJV
Re: Latest update
Post by DL1BJV » Fri Jan 19, 2024 5:43 pm
Hi Brian,
you should find the boot-up to TX option in the ssh Menu.
When you have the Menu on you screen select:
5 System System setup,
In the System setup Menu select:
1 Autostart Automatic Start,
in the Autostart Menu select:
TX_boot Boot-up to Transmit,
To exit the ssh Menu select:
9 Shutdown Shutdown and reboot options,
select reboot and it should now boot to transmit.
Hope this helps.
Wolfgang.
g6hfs
Re: Latest update
Post by g6hfs » Sat Jan 20, 2024 10:08 am
Thankyou, I will take a look.
73,
Thiagoros
Re: Latest update
Post by Thiagoros » Wed Jan 24, 2024 9:10 am
Thank you for latest update.
