Now Safe to Update Ryde
Post by G8GKQ » Sun Oct 22, 2023 1:44 pm
Looks like there are some problems at GitHub who host the Ryde updates and builds. If you we considering trying a Ryde update or new build, suggest you wait until the problems are resolved.
Pa3fbx
Re: Don't Update Ryde at the Moment
Post by Pa3fbx » Sun Oct 22, 2023 2:36 pm
To late...
Hope you resolve the problem...
Just ran an update and now no menu and no red screen...
Post by G8GKQ » Sun Oct 22, 2023 2:52 pm
I hope so Benno. I now have a dead Ryde as well. I could spend an hour rebuilding it from a working one, but I will wait and see....
Pa3fbx
Post by Pa3fbx » Sun Oct 22, 2023 3:25 pm
I just did a rebuilb from the wiki.
it made a instal.sh.1 (added a .1)
used that and it updated not mutch in in 5 minuts i had it working again...
Just for your ref...
Benno
Post by G8GKQ » Sun Oct 22, 2023 7:05 pm
It seems that GitHub have fixed the problem, so it is now safe to build or update.
If you have a dead Ryde caused by a failed update, simple log in to the command line and type
./update.sh
It won't work the first time, so after it reboots log in again, and type
./update.sh
It should then be back to normal.
