Portsdown 4 cannot connect to Pluto
M0NDE
Post by M0NDE » Fri Oct 06, 2023 12:50 pm
I followed the upgrade path for the Pluto. I am happy the update installed. I cannot connect to my Pluto via network cable and my Pi4 does not conn3ct to it. Our tests have shown no ports are open on the Pluto to allow connection. Have I missed out a critical step in preparing the Pluto for Portsdown use?
Re: Portsdown 4 cannot connect to Pluto
Post by G3GJA » Fri Oct 06, 2023 7:13 pm
You need to modify the Ethernet section of the config file in the boot partition of the Pluto with a network address. That address should be in the same network range as the Portsdown and it must not be assigned to some other device.
Check the Portsdown IP address by going to the M2 menu and then press the Info button.
Not all Micro USB to Ethernet adapters work in the Pluto because it does not have drivers for all adapter chips. Generally, adapters with Realtek chips are OK.
Clive
M0NDE
Post by M0NDE » Sun Oct 08, 2023 4:35 pm
Thank you Clive.
Can you recommend a specific make/model/supplier please
Nigel
Post by G3GJA » Sun Oct 08, 2023 10:27 pm
Hi Nigel
An ANKER or UGREEN that has a standard USB A plug used with an OTG USB Micro to USB A socket adapter cable will work.
Try https://amzn.eu/d/axN3lRM and https://amzn.eu/d/hNo6HS7
Clive
