Portsdown 4 Update
Portsdown 4 Update
Post by G8GKQ » Wed Sep 06, 2023 11:42 am
I have just released an update for the Portsdown 4 (Version 202309050). This update is a mixture of new features and bug fixes.
The major bugfix corrects a problem which was caused by Analog Devices updating one of their software utilities (libiio) on 22 Audust 2023. New Portsdown builds made since then have not been able to use the Pluto for transmit or BandViewer.
The new features are mainly concerned with the introduction of the MeteorViewer capability, but introduce techniques that will be re-used to enable BandViewer to use the SDRPlay series of SDRs, and also to allow waterfall displays in BandViewer. The full list of new features include:
  • Portsdown 4 SD Cards can be built on systems without a touchscreen, and if no touchscreen is detected web control is enabled.
  • The Signal Generator Main Menu has been tidied up, and the signal generator can be controlled from a web browser (with or without a touchscreen).
  • The system can be set to boot to Portsdown, Langstone, BandViewer or MeteorViewer.
  • The new MeteorViewer capability can be set to display the waterfall locally or to send the IQ data to the central server (currently at http://95.154.252.125:7682/). Please do not send data to this server without prior coordination with G4NNS.
  • MeteorViewer can be controlled from a web browser without a touchscreen.
I will publish more information on how to use MeteorViewer once the central server capability is more mature, but the default setting should enable local reception of meteor reflections from GB3MBA.
Please report any new bugs here.
arthur21
Re: Portsdown 4 Update
Post by arthur21 » Fri Sep 08, 2023 3:34 pm
Hi Dave
I have just updated my P4 to V:202309050 and now the Pluto Pwr will not change from the 0 setting.
Arthur G4CPE
Post by G8GKQ » Fri Sep 08, 2023 4:03 pm
Hi Arthur
Sorry to hear that.
Please could you run the update again - "Force Update"?
Then if it still won't work, please tell me:
  • What Band
  • What Power you are trying to enter?
arthur21
Post by arthur21 » Fri Sep 08, 2023 6:50 pm
Hi Dave
All OK
I was forgetting to put the minus sign before the number.
Sorry about that, memory lapse this end.
73 Arthur
G4CPE
Post by G8GKQ » Fri Sep 08, 2023 6:52 pm
No problem Arthur!
Pleased that I haven't broken it....
