Valit RX signal toggles
DL5BCA
Post by DL5BCA » Thu Jul 27, 2023 12:53 pm
we used a Ryde receiver for our ATV repeater DB0OV.
It is set to 70cm 437.5MhZ.
I often notice when I've been transmitting on 437.5MhZ and turn off, that the Valit RX signal toggles back and forth several times.
Since we are only showing the signals on which a received signal is detected, the output image toggles back and forth.
It's similar when I turn on my transmitter. First, a signal is detected and a Valit RX signal is output. However, no received signal is decoded yet.
It works like that, no question, and it's "whining at a high level", but maybe we can work on this routine again to minimize the switching?
73 Thomas
I always have crazy ideas.
Please don't be surprised.
