7” lcd screen always on
g6hfs
Post by g6hfs » Wed Jul 12, 2023 1:48 pm
I have been using these commands in ssh to turn the 7” screen off and on is there a way to do this via the touch screen, or could an option be added.
sudo sh -c 'echo "0" > /sys/class/backlight/rpi_backlight/bl_power'
sudo sh -c 'echo "1" > /sys/class/backlight/rpi_backlight/bl_power'
G6HFS
Re: 7” lcd screen always on
Post by G3GJA » Wed Jul 12, 2023 3:27 pm
How would you turn the backlight on from the touch screen if it is not lit?
I don't think I could navigate the menus without being able to see the buttons!
Clive
gm1mfn
Post by gm1mfn » Wed Jul 12, 2023 3:46 pm
A toggle switch in the backlight power path seems like the best option to me.
g6hfs
Post by g6hfs » Wed Jul 12, 2023 4:42 pm
Using those commands turns off the back light only, the touch screen is still active, so touching it could bring the back light back on.
g6hfs
Post by g6hfs » Wed Jul 12, 2023 4:45 pm
Removing power does not work have tried that, when power is switched back on the pi does not see the screen, when you remove power the pi assumes there is no screen.
Post by G8GKQ » Sun Jul 16, 2023 7:44 pm
Hi Brian
Why do you want to turn the screen off?
g6hfs
Post by g6hfs » Sun Jul 16, 2023 8:27 pm
Dave,
Thanks for the reply, I think it's a worry about the same image on screen causing damage or burn type of image on screen, perhaps these screens do hot suffer the same.
Post by G8GKQ » Mon Jul 17, 2023 2:50 pm
Hi Brian
These 7 inch screens do not seem to suffer from burn-in. I certainly can't see any problems on my development Portsdown 4 which is generally powered up for about 8 hours each day - mostly on the main menu.
Not sure that turning the backlight off would have any effect anyway - the pixels are still switched to the displayed image state even without the backlight.
g6hfs
Post by g6hfs » Mon Jul 17, 2023 4:03 pm
Dave,
Thanks for the reply, if I need to turn the back light off I will carry on using the commands to turn off and on.
Cheers
