Source of potty parts
M0NDE
Post by M0NDE » Wed Jun 28, 2023 11:18 am
At the Newbury Rally I tried to find out where to obtain a potty for my dish. Apparently these are available from Holland. Does anyone have details please?
73 Nigel M0NDE
Re: Source of potty parts
Post by radiogareth » Wed Jun 28, 2023 11:58 am
Try here https://www.passion-radio.com/satellite ... 20Es'hail2.
Or here...but he is out of stock, but with links to the original article etc.http://www.hybridpretender.nl/poty.html
Even with basic tools they are not that hard to make, its the patch that needs precision but hacksaw, file, step-drill and 4mm nuts as spacer when you solder the whole lot makes it simpler.
g6hfs
Post by g6hfs » Wed Jun 28, 2023 12:27 pm
Gareth,
Should that be 3mm nut for gap between plates.
Post by radiogareth » Wed Jun 28, 2023 1:07 pm
Brian, no, the gap should be 3mm which (my) 4mm nuts conveniently are 'thickness-wise' ....
g6hfs
Post by g6hfs » Wed Jun 28, 2023 3:07 pm
Gareth,
had not realised a 4mm nut is 3mm thick 🤣🤣
Post by g0mjw » Wed Jun 28, 2023 8:01 pm
Nutters :D - M4 nuts are often 3mm thick, but measure it. The right gap is the most difficult bit.
There are some on Ebay but they are pricy. You could make your own, it isn't that hard, that was the point of the design, it could have been more complicated, with better performance, dual feed points, phasing lines, wider bandwidth, better circularity, but hard to make. I wanted to design a simple single point feed that almost anyone could replicate, a square piece of copper or brass with the corners cut off, a round bit and a length of 22mm copper water pipe. The compromise is the bandwidth, which is only a few percent, but if you are careful with the measurements, it should work, perhaps with a little bending. If you make the patch from copper it will be much easier to tweak by bending. With brass, you have to bend it more than required and hope it springs back to the right place.
g6hfs
Post by g6hfs » Mon Aug 21, 2023 9:08 am
https://shop.amsat-uk.org/product/poty
7 in stock but ready built
Post by G8GKQ » Mon Aug 21, 2023 10:54 am
The metalwork on those AMSAT feeds is OK, but I have heard that the dielectric lens is not optimum for DATV use.
g6hfs
Post by g6hfs » Mon Aug 21, 2023 12:34 pm
Hi Dave.
Yes, people also buy the rocket lnb and take the lens off and use on poty.
G3VZV
Post by G3VZV » Tue Aug 29, 2023 11:34 am
Ready built ones are now listed at the AMSAT-uk shop.
Only 4 left in stock at the moment though! https://shop.amsat-uk.org/product/poty
Graham G3VZV
