How can I easy set Horizontal as default LNB power and reduce to only one NIM?
Store LNB power and set to one tuner
Re: Store LNB power and set to one tuner
Could you not just rotate the LNB 90 degrees so it needs 12V for the WB?
Just found the setting for the LNB power. Only question left is to disable the 2nd tuner. In the spectrum view I can only tap on the top range of the screen. How can I enable to use the whole screen to tap on?
The next version is a bit smarter and will adjust the spectrum based on the amount of transport streams. If you only have 1 transport active then it will work as the normal spectrum with a single signal for the whole screen. Should be released tonight depending on testing.
T
