Pluto firmware 0303 DATV settings.
M5TXJ
Post by M5TXJ » Sat Apr 29, 2023 1:02 pm
Hi all,
The slow progress towards H265 (and eventually H266) continues. I now have a second Pluto for use external to the Portsdown 4 and have loaded 0303 firmware to it. What settings do I need to set in the homepage of the 0303 firmware? This Pluto is connected directly to the PC by USB and I have DATV-Easy v2.17 on the PC.
Thanks and 73 Dave.
Re: Pluto firmware 0303 DATV settings.
Post by g0mjw » Sat Apr 29, 2023 3:18 pm
The right ones Dave. I have them set up here. not sure if this will work. This is mostly the defaults. Clearly your IP address will be different.
PlutoDVB General setup.pdf
(487.43 KiB) Downloaded 830 times
M5TXJ
Post by M5TXJ » Sat Apr 29, 2023 3:24 pm
Thanks Mike, I'll have a play tomorrow, I'm guessing the OBS IP is the PC OBS is running on.
Dave.
Post by g0mjw » Sat Apr 29, 2023 3:30 pm
No, well yes, well maybe. I suppose it could be if you wanted to control from the Pluto, or maybe it is the last one that did so, but I ignore that setting just stream to it with a script or DATV Easy. That works from any PC on the network and even the world if I open up the right ports. Evariste was able to stream to it when we tested it.
M5TXJ
Post by M5TXJ » Sat Apr 29, 2023 3:39 pm
Makes perfect sense, well it will to someone... :lol: :lol: :lol:
