WinterHill install issue
F1CJN_alain
Post by F1CJN_alain » Mon Apr 24, 2023 4:21 pm
I tried with the last version of the RPI OS using Raspberry Pi Imager (declaring country, SSH , Wifi ...) and with two different micro SD cards.
And I got twice this message at the end of the procedure:
---- Building spi driver for install -----
make -C /lib/modules/5.15.84-v7l+/build/ M=/home/pi/winterhill/whsource-3v20/whdriver-3v20 modules
make[1]: *** /lib/modules/5.15.84-v7l+/build/: No such file or directory. Stop.
make: *** [Makefile:4: all] Error 2
- Failed to build the WinterHill Driver --
Any idea ?
Best 73's
Alain F1CJN
Re: WinterHill install issue
Post by G4EWJ » Mon Apr 24, 2023 4:36 pm
The WH driver build is very specific to the revision of Linux in use, but it should be self-adjusting. It seems that it did not find the specific files. I will try a new build here.
Can you do:
uname -mrsa
and post the results.
F1CJN_alain
Post by F1CJN_alain » Mon Apr 24, 2023 4:48 pm
Hi Brian
pi@raspberrypi:~ $ uname -mrsa
Linux raspberrypi 5.15.84-v7l+ #1613 SMP Thu Jan 5 12:01:26 GMT 2023 armv7l GNU/Linux
73s
alain F1CJN
Post by G4EWJ » Mon Apr 24, 2023 5:06 pm
Thanks. Your version is 5.15. Have you downloaded Bullseye? It needs to be this Buster version 5.10:
Raspberry Pi OS (Legacy) with desktop
Release date: February 21st 2023
System: 32-bit
Kernel version: 5.10
Debian version: 10 (buster)
Show SHA256 file integrity hash:
Release notes
F1CJN_alain
Post by F1CJN_alain » Mon Apr 24, 2023 11:04 pm
Hi Brian
I downloaded the Buster and everything runs ok.
It is now a pleasure to watch the A71A 1500k video signal on the screen
I have a little more to do on the receiver (MIC input regulator, LNB voltage circuits, second tuner). Components and printed circuits are on the way to home.
Thanks a lot
Best 73's
Alain F1CJN
Post by G4EWJ » Mon Apr 24, 2023 11:34 pm
Very good. I hope that you can find all the components.
