LimeSDR XTRX
VK3IE
LimeSDR XTRX
Post by VK3IE » Mon Mar 06, 2023 7:41 pm
LimeSDR XTRX An embeddable, high-performance SDR in a Mini PCIe form factor
May have a fair price, has to its way smaller.. :roll:
LimeSDR XTRX is high-performance software-defined radio (SDR) board in a compact Mini PCIe form factor. With an AMD (formerly Xilinx) Artix-7 XC7A50T-2CPG236I FPGA and a Lime Microsystems LMS7002M RF transceiver at it’s core, LimeSDR XTRX is a perfect platform for developing logic-intensive digital and RF designs.
LimeSDR XTRX is a suitable building block for MIMO configurations from 2Tx2R to 32Tx32R. It can be used in conjunction with digital processors (ASICs, GPPs and GPUs) of varying speed, power dissipation, and cost to fit any air interface, whether narrowband or broadband. The board is designed for the following key feataures:
Frequency and Bandwidth: The heart of the board is the Lime transceiver RFIC (LMS7002), covering frequencies up to 3.8 GHz with a bandwidth of over 100 MHz.
Baseband Interface: A significant level of digital circuitry resides within the LMS7002 and accompanying FPGA for the implementation of key physical layer radio functions, including filtering, decimation, interpolation, and flexible interfaces such as PCIe and SerDes.
As found here:
https://www.crowdsupply.com/lime-micro/limesdr-xtrx
Cheers
