70cm DATV
70cm DATV
Hi All,
I would like to try a Datv 70cm transmission to the UK.
Is there any repeater that can receive this signal from Holland ?
And where do I find the settings for this transmission.
Feq - and other settings ! !
Regards Jan / Pd0hni
Re: 70cm DATV
GB3JV JO01AJ has a very sensitive 70cms input with a Big Wheel omni. I have accessed it from over 100km away (with 150W and a beam).
Send DVBs or S2 at 333kS and check the stream.
Good luck.
Good luck.
Re: 70cm DATV
Thank you Gareth,
Could you tell me on what frequency you operate in the UK
In Holland we use 436.00 at PI6ATV repeater.
Jan / Pd0hni
Jan / Pd0hni
Re: 70cm DATV
Oke Martin,
I will look for it.
Jan / Pd0hni
I will look for it.
Jan / Pd0hni
Re: 70cm DATV
Just to clarify, we have, as far as I am aware, no 70cm DATV repeater outputs. The band is shared with the satellite band and the primary user. There are now a few 70cm repeater inputs, typically on 437 MHz.
Ideally these should try to avoid the satellite segment 435-438MHz. In the US they use 438.250MHz for video inputs in their much wider 70cm band. Perhaps we should do the same for DAVT repeater inputs? However, the RSGB are still a bit behind the curve and only think of FM, DMR and DV and have little knowledge of reduced bandwidth DATV, so have indicated 438-440 MHz should be no wider than 25 kHz. This forces DATV into the 435-438 MHz segment and interference between satellite and DATV is a problem. The RSGB band plan says about 435-438 MHz that "This area of the band is also shared with digital fast-scan television (DATV) centred at 437 MHz, although ATV operators are also encouraged to use microwave allocations where available."
Interference is not a large problem yet because DATV use of 70cm is still quite limited, but if we were to set up a network of DATV repeaters with inputs in this range it could quickly become a problem as there are many many more satellites than there were in the 1980s and DATV is growing quickly. There is much synergy/overlap between the two now we have QO100, HAMTV etc. It would be very nice to have a 70cm DATV output slot, say 500kHz, especially as we may lose 23cm. That could be paired with an official input channel.
Re: 70cm DATV
Thank you for the response
Jan / Pd0hni
Jan / Pd0hni
