LeanDVB still there?
pe1jpd
Post by pe1jpd » Tue Jan 17, 2023 1:32 pm
I have run the portsdown 4 software with only a Pluto, so no Rx. Therefore I am interested in including the LeanDVB solution as can be found on the web. Is this still possible in the current versions? Information I found is outdated and compilation run into errors.
73 Bas PE1JPD
Re: LeanDVB still there?
Post by G8GKQ » Tue Jan 17, 2023 5:16 pm
Hi Bas
No, LeanDVB is only supported on the Portsdown 2020. And then only with an RTL-SDR.
Also, LeanDVB only worked for DVB-S, not DVB-S2, so would only decode a small percentage of today's transmissions.
