mini-HDMI ports
IU2KAC
mini-HDMI ports
Post by IU2KAC » Mon Jan 16, 2023 7:22 pm
I rephrase the question, could someone explain to me what the 2 mini-HDMI ports are for?
Thank you.
M1DNS
Re: mini-HDMI ports
Post by M1DNS » Fri Jan 27, 2023 6:54 pm
None, as theyre not used in a portsdown setup.
If you plug a screen in all you'll most prob. see is a command prompt, if that even.
IU2KAC
Re: mini-HDMI ports
Post by IU2KAC » Fri Jan 27, 2023 8:13 pm
On Menu 2 of Portsdown 4 there is "HDMI Monitor" what is it for?..
Re: mini-HDMI ports
Post by G3GJA » Fri Jan 27, 2023 8:26 pm
Not currently implemented / for future development
Clive
Re: mini-HDMI ports
Post by g0mjw » Fri Jan 27, 2023 8:27 pm
There are instructions on the Wiki, but it is to monitor an HDMI input dongle. The HDMI ports are standard on the pi, but not used in Portsdown. Please check the Wiki first. https://wiki.batc.org.uk/The_Portsdown_ ... ver_system it answers most questions.
IU2KAC
Re: mini-HDMI ports
Post by IU2KAC » Fri Jan 27, 2023 8:42 pm
Is it possible to stream on my local network and view it with VLC?..
Re: mini-HDMI ports
Post by g0mjw » Fri Jan 27, 2023 8:51 pm
Please please just look at the Wiki. This is answered here https://wiki.batc.org.uk/Configuring_yo ... _Portsdown but if you mean stream the received video, look here
https://wiki.batc.org.uk/The_Portsdown_ ... V_receiver where you will find the answer.
The received signal is displayed on the 7" touch screen. It is also available as a UDP output on the network enabling it to be viewed on a larger PC using VLC or a similar software.
