29MHz transverter PCs in shop
The place for announcements on the latest stock items and for your feedback on items that you would like to see in stock
Post by g8gtz » Tue Jan 10, 2023 8:25 pm
The PCB for the 29MHz transverter is now in the shop:
https://batc.org.uk/shop/29mhz-transverter-blank-pcb/
Full construction details are on the wiki:
https://wiki.batc.org.uk/29MHz_transverter
Re: 29MHz transverter PCs in shop
Post by g0mjw » Tue Jan 10, 2023 8:34 pm
There are cheap TCXOs here https://www.ebay.co.uk/itm/202891111938 - you don't need the trimming pot. Only disadvantage is you can't tune them spot on frequency, but that's not such a hardship given the Serit Tuner is also not all that accurate.
You can also save a lot of money buying cheap SMAs from Ebay or Aliexpress rather than the expensive ones from distributors. There are cheap mixers too that work OK. Intelligent shopping should halve the parts cost. Just don't skimp on the inductors and MMICs.
VK3IE
Post by VK3IE » Tue Oct 22, 2024 6:05 am
Hi Mike
Few guys in VK are looking at this 29mhz....
Just checking if there has been any changes or alterations to the current BOM datted 12/2022
Robert
vk3ie
Post by g0mjw » Tue Oct 22, 2024 7:56 am
Hi Robert
No but... my experience with Digikey and Mouser is that parts change quickly. They go out of stock, or get replaced by practically the same part, but with a different part number. You may find after 2 years that many of the parts in the BOM appear to not be available. They are largely generic so it is relatively easy to substitute as long as you know what you are doing.
EDIT - I should add, don't waste your money on high quality SMA connectors - this is HF/VHF so even the cheap ones will work fine, just make sure they will fit. They are in the BOM for completeness. A quick check showed that practically all the resistors are unavailable, having been replaced by newer parts, but they are just resistors.
VK3IE
Post by VK3IE » Wed Oct 23, 2024 12:20 am
Thanks Mike
All Good
I uploaded a bom to Digikey and only 2 items were out of stock at the time, part numbers sorted them self out OK
It was more a check just in case of mods and being a couple of years old, good to ask.
PCB is on the way from BATC
Good Info
Cheers
Robert
vk3ie
Return to “BATC Shop”
