VB Audio Cable setup
M5TXJ
Post by M5TXJ » Tue Jan 10, 2023 12:43 pm
Hi all,
In my quest to move to H265 I've moved to DATV Easy and OBS with VB Audio cable, however I can't TX any audio, could someone give me an idiots guide to setting up? Installation went fine and VB is listed in the devices. All help gratefully received.
73 Dave.
G8KOE
Re: VB Audio Cable setup
Post by G8KOE » Tue Jan 10, 2023 6:05 pm
Go to settings in OBS
Audio
Advanced
Monitoring Device set to “ CABLE Input (VB-Audio Virtual Cable) click OK to Apply.
Now go to Audio Mixer in OBS and click on the two cogs bottom left.
This will open Mixer settings go to the channel or channels that you want to relay.
Under Audio Monitoring select “Monitor and Output”
Then Close that’s the audio done.
Set DATV Easy input to "OBS+VB-AudioCABLE"
Hope that helps
Martin
G8KOE
M5TXJ
Post by M5TXJ » Tue Jan 10, 2023 7:13 pm
Hi Martin,
Thanks for that info, I will give that a go when I put my station back together, I'm currently rejigging my Portsdown 4.
73 Dave.
