I am using a Portsdown4 and Langstone combination. When I start Portsdown all is Ok. When I then switch to Langstone using the menu in Portsdown 4 the Langstone starts but for the first few say 20 seconds I get the screen message "PLUTO NOT RESPONDING". Then all appears to be OK.
Is this problem known or does anyone have an idea what I can check. The voltage supply to the Pluto and RPI is 5.1V.
I have tried searching the Forums but this specific problem does not appear to be raised.
Pluto not responding
Re: Pluto not responding
See page 32 of the latest CQ-TV, there is a fix there.
The Pluto is a lot happier at 4.9V (or even 4.8) but the RPI complains if you go below 5V.
Adding a Schottky diode in the positive lead to the Pluto seems to fix it.
I have just done this mod to mine, I can't find my 1A diodes so cannibalised a SS54 from a u/S SMPSU (5 amp device which showed a Vf of about 0.25 at low current multimeter test).
My RPI sits at 5.15 and the Pluto so far is entirely happy.
I am using short ANKER brand USB leads and its the RED wire that carries +5V, as you would hope....
Good luck.
Good luck.
Powering the Pluto from the dedicated micro USB power socket is an alternative to fitting the diode. Stability is excellent.
Much easier to implement too.
Clive G3GJA
Clive G3GJA
Many thanks for all the suggestions, I will give it a try.
73 and a HAPPY NEW YEAR.
