LimeSDR with Windows 11 and DATV Easy possible?
PE5PVB
Post by PE5PVB » Thu Sep 29, 2022 9:24 am
I have a Lime SDR mini and want to use it on my Windows 11 PC with DATV Easy software. When I start the stream I see an unmodulated RF carrier on my spectrum analyser on the wanted frequency, and I'm able to change the output level with the slider, but no modulation.
What is wrong? Do I need to user other drivers or install special firmware on the Lime SDR? When I use it with my Portsdown it's working fine.
G7JTT
Re: LimeSDR with Windows 11 and DATV Easy possible?
Post by G7JTT » Fri Sep 30, 2022 9:35 am
I use Windows 11 and a lime and DATV easy and it works fine. You need to install the ftdi drivers otherwise windows installs the wrong driver.
https://ftdichip.com/drivers/d3xx-drivers/
Hope this helps 73 John
PE5PVB
Post by PE5PVB » Fri Sep 30, 2022 10:01 am
I already found the probleem. I removed the DVB firmware, now it’s ok.
G7JTT
Post by G7JTT » Fri Sep 30, 2022 3:45 pm
Excellent 👌
Return to “LimeSDR Mini”
