Junk for disposal
Junk for disposal
Post by g8gtz » Tue Sep 27, 2022 3:08 pm
I received this email from Kevin GW0PUH:
Many years ago I worked in the cable TV industry and acquired a lot of equipment when the company closed down. (It had a bit of a history Rediffusion, Maxwell Cable TV, Metro Cable TV and then CableTel/NTL before closing)
I have some items to dispose of, I would rather someone make use of them than giving them to the scrapman. They are free, I need to drag them all out of storage and they would have to be collected.
List that I have found so far:
Phillips PM5535 pattern generator
Phillips PM5544 pattern generator
Phillips PM5582 IF-UHF up-converter
Phillips PM5581 IF-VHF up-converter
Tektronix PAL waveform monitor
2 off Jeffold/GI 50-450MHz PAL modulators
2 off HP141T Spectrum analyzers, 110MHz plug-in and 18GHz plug-in. (Maybe a thrd 1.5Ghz)
3 off Tracking generators (I think the multi cable was missing when I got them)
Wiltron 640? Scaler Network Analyzer
Approx 6-8 Dynamco 7100 oscillscopes some with TV trigger plug-in
Unaohm pattern generator
This pile is a mixture of working and not, I may have more. I know there are certainly some Katrein amplifiers and maybe some other 75 ohm test equipment, attenuators and cables etc.
I'm located in Pontypool South Wales.
Please email me at secretary@BATC.TV and I''ll forward the message to Kevin.
davezawadi
Re: Junk for disposal
Post by davezawadi » Sun Feb 05, 2023 5:55 pm
Does the 18 GHz 141T plug-in work, usually have duff first mixer and these are not amateur repairable being wirebonded hybrids. If it does the I am interested.
David G8FNR
Davezawadi@yahoo.co.uk
