Ryde nim A and B socket inputs
g6hfs
Post by g6hfs » Mon Aug 01, 2022 11:46 pm
I have a question, can you only select A or B nim inputs via ssh then menu, is there a way of selecting A or B within the main display screen, if not can it be added in an update as it will make it quicker to select when switching between different type aerials on the same frequency, just a thought.
Brian G6HFS
MW0RUD
Re: Ryde nim A and B socket inputs
Post by MW0RUD » Tue Aug 02, 2022 6:51 pm
Hi Brian,
If you setup 2 identical bands apart from the port, you can then switch between them from the menu.
Tim
g6hfs
Post by g6hfs » Wed Aug 03, 2022 11:23 am
Hi Tim,
Is that using say 2 custom setups or say custom 1255 and 1255 333 for arguments sake.
Cheers
Brian G6HFS
