BATC ATV Repeater controller. Basics for new users
PE5PVB
Post by PE5PVB » Tue May 24, 2022 1:16 pm
I found this project on the GitHub and installed it on a RP4. I now see a slideshow of pictures, but I can't find any information how to control it and use it. Documentation is very raw. I am checking if it can be used for our local ATV repeater, but how can I control the repeater? How can I add inputs, when using USB dongles to convert analog input signals, is it realtime? Is there by change anyone who can guide me through the first steps?
Re: BATC ATV Repeater controller. Basics for new users
Post by g0mjw » Tue May 24, 2022 1:22 pm
Did you intend to provide a link?
PE5PVB
Post by PE5PVB » Tue May 24, 2022 1:35 pm
Link?
Post by g8gtz » Tue May 24, 2022 2:00 pm
All the information you require is here: https://wiki.batc.org.uk/Repeater_Controller
Any questions just ask.
PE5PVB
Post by PE5PVB » Tue May 24, 2022 3:11 pm
Dear Noel,
I already found that page, but it's unclear to me how to control everything. Is it only possible through DTMF or also by a webcontrol? How can I add an analog USB converter to the system and enable this? How can I switch off the slideshow and show the Picture in Picture screen?
Post by G8GKQ » Tue May 24, 2022 3:22 pm
The controller simply controls an external HDMI switch. If you give it a "signal valid" indication on one of the GPIO inputs defined in the config file, it will command the switch to show that output.
The Controller does not handle incoming video (HDMI or Analog) It only provides the slideshow and the captions, so is part of a much larger system.
Have you read the article about it in CQ-TV 275?
PE5PVB
Post by PE5PVB » Tue May 24, 2022 3:39 pm
Dave,
I'll look into the article. So it can not generate a picture in picture view of all inputs?
Post by G8GKQ » Tue May 24, 2022 3:42 pm
No, the picture in a picture is generated in the "seamless" HDMI switch which uses a framestore.
The primary test system is live here https://batc.org.uk/live/gb3hv but is undergoing maintenance prior to this evening's GB3HV net at 2000 UK time.
PE5PVB
Post by PE5PVB » Tue May 24, 2022 3:49 pm
Are you sure about the edition number? :D
Post by G8GKQ » Tue May 24, 2022 4:31 pm
Yes - page 11
