Android Remote Control for Ryde Receiver
zr6tg
Post by zr6tg » Fri May 20, 2022 3:27 pm
I've recently added another Minitiouner to the shack and set it up as a Ryde Receiver.
I didn't have all the additional hardware to add the necessary components for an infra-red remote so I decided to put together a remote control for my android phone which controls the Ryde Receiver via my network.
If you want to give it a try then you can download the https://www.zr6tg.co.za/files/app-relea ... 1-test.apk here and try it out. Setup is simple, just select the settings button (bottom right button) and provide your ryde receiver ip and port.
This can be improved lots of ways, but for a regular quick and easy remote to get going on the ryde receiver, it works perfectly :)
Feedback welcome as always, 73
Tom - ZR6TG
g8lce
Re: Android Remote Control for Ryde Receiver
Post by g8lce » Sat May 21, 2022 8:40 am
Hope this helps. I put the link into a QR generator and here is the result. Be it on your own head......
Martin G8LCE
g8ayc
Post by g8ayc » Tue May 24, 2022 3:31 pm
Works perfectly. Many thanks, Tom, for a very useful app.
Thanks also to G8LCE for making the installation easy!
73 Nigel G8AYC
zr6tg
Post by zr6tg » Sat May 28, 2022 6:11 pm
If you aren't comfortable downloading and installing a random apk, then I've now also managed to get it on Google Playstore:
https://play.google.com/store/apps/deta ... te_control
APK is still freely available as per normal
Martin G8LCE
Thanks!, this makes things easier as well.
73, ZR6TG
g6hfs
Post by g6hfs » Thu Jun 23, 2022 11:24 pm
Hi Tom,
perhaps I missed something you say: just select the settings button (bottom right button) and provide your ryde receiver ip and port.
I know my ip address, but how do you find your port number, thanks
Brian G6HFS)
G8HKN
Post by G8HKN » Fri Jun 24, 2022 12:14 pm
Hi Brian,
I have Done this recently
The IP Scanner came up with several Addresses.
After many tries I used the Default Port which came with the App
of 8765 and is working well with Ethernet cable connected from my BT Hub to Pi4
Hope this helps
73 Roger G8HKN
g6hfs
Post by g6hfs » Fri Jun 24, 2022 5:22 pm
Hi Roger,
Thanks, will give that ago next time it’s booted up.
Brian (G6HFS)
g6hfs
Post by g6hfs » Sun Jun 26, 2022 11:21 am
Can this remote on android phones work with the WinterHill project, just asking
Brian (G6HFS)
zr6tg
Post by zr6tg » Tue Jun 28, 2022 5:21 am
Hi Tom,
Brian G6HFS)
Hi Brian,
Apologies for late reply, only saw the messages now. Unless you changed the configuration on your Ryde install the default port will always be 8765 (I should probably put that in the app). Let me know if you came right :)
73,
T
zr6tg
Post by zr6tg » Tue Jun 28, 2022 5:22 am
Brian (G6HFS)
No, not currently. Not sure it would make sense with the current buttons, but if there is a need then a control app for android can be made to control winterhill. Let me know and I can look into it.
T
