Standalone Longmynd Installation
zr6tg
Post by zr6tg » Wed May 04, 2022 3:23 pm
Hi All,
I'm looking into getting a standalone longmynd installed from (https://github.com/philcrump/longmynd/) on a freshly installed pi. I'm getting the following compilation error thought:
Compiling longmynd with GCC 10.2.1 on arm-linux-gnueabihf
INFO: Need to [re]initialize git submodules
Submodule 'web/libwebsockets' (https://github.com/warmcat/libwebsockets.git) registered for path 'web/libwebsockets'
Cloning into '/home/pi/longmynd/web/libwebsockets'...
Submodule path 'web/libwebsockets': checked out 'd18e1db72c0032fe26912e578ada320e9665acff'
INFO: Need to compile libwebsockets
-- The C compiler identification is GNU 10.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Compiled with LWS_WITH_DIR and LWS_WITH_LEJP_CONF
Deselecting EVLIB_PLUGINS since building static
-- Found Git: /usr/bin/git (found version "2.30.2")
Git commit hash: v4.1.6-12-gd18e1db7
-- Performing Test LWS_HAVE_inline
-- Performing Test LWS_HAVE_inline - Success
-- Performing Test LWS_HAVE___inline__
-- Performing Test LWS_HAVE___inline__ - Success
-- Performing Test LWS_HAVE___inline - Success
-- Performing Test LWS_HAVE_MALLOC_TRIM
-- Performing Test LWS_HAVE_MALLOC_TRIM - Success
-- Performing Test LWS_HAVE_MALLOC_USABLE_SIZE
-- Performing Test LWS_HAVE_MALLOC_USABLE_SIZE - Success
-- Looking for fork
-- Looking for fork - found
-- Looking for getenv
-- Looking for getenv - found
-- Looking for malloc
-- Looking for malloc - found
-- Looking for memset
-- Looking for memset - found
-- Looking for realloc
-- Looking for realloc - found
-- Looking for socket
-- Looking for socket - found
-- Looking for strerror
-- Looking for strerror - found
-- Looking for vfork
-- Looking for vfork - found
-- Looking for execvpe
-- Looking for execvpe - found
-- Looking for getifaddrs
-- Looking for getifaddrs - found
-- Looking for snprintf
-- Looking for snprintf - found
-- Looking for _snprintf
-- Looking for _snprintf - not found
-- Looking for _vsnprintf
-- Looking for _vsnprintf - not found
-- Looking for getloadavg
-- Looking for getloadavg - found
-- Looking for atoll
-- Looking for atoll - found
-- Looking for _atoi64
-- Looking for _atoi64 - not found
-- Looking for _stat32i64
-- Looking for _stat32i64 - not found
-- Looking for clock_gettime
-- Looking for clock_gettime - found
-- Looking for in6addr.h
-- Looking for in6addr.h - not found
-- Looking for memory.h
-- Looking for memory.h - found
-- Looking for netinet/in.h
-- Looking for netinet/in.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stdlib.h
-- Looking for stdlib.h - found
-- Looking for strings.h
-- Looking for strings.h - found
-- Looking for string.h
-- Looking for string.h - found
-- Looking for sys/prctl.h
-- Looking for sys/prctl.h - found
-- Looking for sys/socket.h
-- Looking for sys/socket.h - found
-- Looking for sys/sockio.h
-- Looking for sys/sockio.h - not found
-- Looking for sys/stat.h
-- Looking for sys/stat.h - found
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for unistd.h
-- Looking for unistd.h - found
-- Looking for vfork.h
-- Looking for vfork.h - not found
-- Looking for sys/capability.h
-- Looking for sys/capability.h - not found
-- Looking for malloc.h
-- Looking for malloc.h - found
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for inttypes.h
-- Looking for inttypes.h - found
-- Looking for sys/resource.h
-- Looking for sys/resource.h - found
-- Looking for cap_set_flag in cap
-- Looking for cap_set_flag in cap - not found
-- Looking for 3 include files stdlib.h, ..., string.h
-- Looking for 3 include files stdlib.h, ..., string.h - found
-- Performing Test LWS_HAS_INTPTR_T
-- Performing Test LWS_HAS_INTPTR_T - Success
-- Performing Test LWS_HAS_PTHREAD_SETNAME_NP
-- Performing Test LWS_HAS_PTHREAD_SETNAME_NP - Failed
-- Performing Test LWS_HAS_GETOPT_LONG
-- Performing Test LWS_HAS_GETOPT_LONG - Success
-- Performing Test LWS_HAVE_VISIBILITY
-- Performing Test LWS_HAVE_VISIBILITY - Success
-- Performing Test LWS_GCC_HAS_IGNORED_QUALIFIERS
-- Performing Test LWS_GCC_HAS_IGNORED_QUALIFIERS - Success
-- Performing Test LWS_GCC_HAS_TYPE_LIMITS
-- Performing Test LWS_GCC_HAS_TYPE_LIMITS - Success
-- Looking for eventfd_read
-- Looking for eventfd_read - found
-- Performing Test LWS_HAVE_PIPE2
-- Performing Test LWS_HAVE_PIPE2 - Success
-- Performing Test LWS_HAVE_TCP_USER_TIMEOUT
-- Performing Test LWS_HAVE_TCP_USER_TIMEOUT - Success
DIR /home/pi/longmynd/web/libwebsockets/build CMP /home/pi/longmynd/web/libwebsockets/cmake
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/longmynd/web/libwebsockets/build
make[1]: Entering directory '/home/pi/longmynd/web/libwebsockets/build'
make[2]: Entering directory '/home/pi/longmynd/web/libwebsockets/build'
make[3]: Entering directory '/home/pi/longmynd/web/libwebsockets/build'
Scanning dependencies of target GENHDR
make[3]: Leaving directory '/home/pi/longmynd/web/libwebsockets/build'
[  1%] Creating build include dir
[  1%] Built target GENHDR
Scanning dependencies of target websockets
[  3%] Building C object lib/CMakeFiles/websockets.dir/plat/unix/unix-caps.c.o
[  5%] Building C object lib/CMakeFiles/websockets.dir/plat/unix/unix-misc.c.o
during RTL pass: reload
/home/pi/longmynd/web/libwebsockets/lib/plat/unix/unix-misc.c: In function ‘lws_now_usecs’:
/home/pi/longmynd/web/libwebsockets/lib/plat/unix/unix-misc.c:60:1: internal compiler error: Segmentation fault
   60 | }
0xb6a1ed9f ???
        ../sysdeps/unix/sysv/linux/arm/sigrestorer.S:64
0xb6a06bdf __libc_start_main
        ./csu/libc-start.c:308
Please submit a full bug report,
with preprocessed source if appropriate.
Please include the complete backtrace with any bug report.
See <file:///usr/share/doc/gcc-10/README.Bugs> for instructions.
make[3]: *** [lib/CMakeFiles/websockets.dir/build.make:95: lib/CMakeFiles/websockets.dir/plat/unix/unix-misc.c.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:1321: lib/CMakeFiles/websockets.dir/all] Error 2
make[2]: Leaving directory '/home/pi/longmynd/web/libwebsockets/build'
make[1]: *** [Makefile:182: all] Error 2
make[1]: Leaving directory '/home/pi/longmynd/web/libwebsockets/build'
make: *** [Makefile:76: check-lws] Error 2
Anyone experienced this before ? Dependencies installed as per github docs
T
Re: Standalong Longmynd Installation
Post by G8GKQ » Wed May 04, 2022 7:05 pm
Phil's longmynd is not the clean install. He has many other functions in his personal build.
Try this one: https://github.com/BritishAmateurTelevi ... b/longmynd
zr6tg
Re: Standalone Longmynd Installation
Post by zr6tg » Sat May 07, 2022 10:45 am
Thanks, but looking specifically to use that version. Also having the same issue with the batc version, so might be on my side. I've got Phil's version working on a linux machine for now for testing. I'll setup a new clean pi and try again :)
Thanks,
Tom
zr6tg
Post by zr6tg » Mon May 09, 2022 8:02 am
All sorted, looks like best version to use currently is Raspberry PI OS (Legacy) - Buster - 2022-04-04 version
Basic instructions for future reference :)
sudo apt-get install cmake git make gcc libusb-1.0-0-dev libasound2-dev
git clone https://github.com/philcrump/longmynd.git
cd longmynd && make
sudo cp minitiouner.rules /etc/udev/rules.d/
Thanks!
