Langstone kein touchscreen
DL8ZAD
Post by DL8ZAD » Mon Apr 25, 2022 11:21 am
hallo,
ich habe mir den Langstone TRX gebaut, dazu das touch display für den raspberry verbaut. Leider funktionert die Verbindung touchscreen zur Anwendung nicht. Das Display habe ich getestet mit dem HW_test. Das Display gibt die touchpostion an HW_test weiter. Aber in der Langstoe software funktioniert das leider nicht. kann mir da jemand einen rat Geben damit ganze funktioniert?
Re: Langstone kein touchscreen
Post by g4eml » Mon Apr 25, 2022 2:35 pm
Translation.
I built the Langstone TRX and installed the touch display for the raspberry. Unfortunately, the touch screen connection to the application does not work. I tested the display with the HW_test. The display passes the touch position to HW_test. Unfortunately, this does not work in the Langstoe software. can someone give me advice so that everything works?
Which screen are you using? You may need to change the display rotation in /boot/config.txt if it is not the official 7” touchscreen.
DL8ZAD
Post by DL8ZAD » Mon Apr 25, 2022 5:38 pm
Colin,
thanks a lot... it runs...
DL8ZAD
Post by DL8ZAD » Tue Apr 26, 2022 9:24 am
I will make a small description of my problem and its solution..
Return to “Deutschsprachiges Forum”
