Signal Generator error with Lime Mini
Post by G3GJA » Fri Mar 04, 2022 2:56 pm
I think I have found a bug in the sig gen. My Portsdown has the latest update installed. I have both the Pluto and Lime Mini SDRs installed.
Whilst checking the Portsdown sig gen frequency accuracy using a counter with a GPS disciplined clock, I noticed a problem when using the Lime Mini. The output is exactly 1MHz low of the displayed frequency; I used 1275MHz. It was actually a further 173Hz low, but that's just down to the Lime's onboard clock.
If I switch to the Pluto, it comes out on the correct frequency, ignoring the -14kHz offset due to the Pluto's 40MHz clock error.
My Lime is on frequency in DVB-S/S2 modes.
Can someone confirm this issue? Not a high priority for Dave, but I know some of us have been using the sig gen to align gear.
Clive
Re: Signal Generator error with Lime Mini
Post by G8GKQ » Fri Mar 04, 2022 4:03 pm
Hi Clive
Do you have the LimeDVB firmware loaded on your LimeSDR?
If so, that would account for the issue. The SigGen sets the Lime LO to 1 MHz below the desired frequency and then uses the internal oscillator to generate a 1 MHz signal that is applied as USB to the LO. This allows better control of the output amplitude.
The 1 MHz LO is not available with the LimeDVB firmware, so the only output is the LO; 1 MHz below the desired frequency. Unfortunately, I have been unable to find a reliable way of detecting the loaded firmware, otherwise I would implement a warning.
There is no problem with switching between the firmwares; I checked with the designers - it's an EEPROM with a 10,000 write cycle life.
It could also be that you haven't calibrated after a frequency change - this leads to poor LO suppression.
Post by G3GJA » Fri Mar 04, 2022 5:11 pm
Hi Dave
Yes, I do have the Lime DVB firmware installed.
I have GPS locked HP sig gen to 2.06GHz and the not so accurate Pluto to provide a signal up to 4.4GHz, so I won't bother with switching the firmware unless I'm desperate for something more accurate above 2GHz.
I'd probably be better off using the second harmonic of the HP!
Clive
Post by G8GKQ » Fri Mar 04, 2022 5:23 pm
Thanks Clive
I've updated the Wiki with this information. https://wiki.batc.org.uk/Portsdown_4_Si ... put_Device
