Resolution
G6MNJ
Resolution
Post by G6MNJ » Sat Feb 19, 2022 7:06 pm
I am a big fan of the Portsdown transmitter however whilst we can change symbol rate, fec etc there seems no provision for the resolution.
I guess the testcard jpg is set at a given resolution so that determines that, but what about the USB video capture device or Pi Cam how is their resolution decided and can it be altered?
Paul G6MNJ
Re: Resolution
Post by G8GKQ » Sat Feb 19, 2022 7:28 pm
Hi Paul
The resolution options are selected from the "Format" button on Menu 1.
The full list includes :
  • 4:3 which is usually 720x576
  • 16:9 which is usually something like 1024x576
  • 720p which is 1280x720
  • 1080p which is 1920x1080
However, only the lower resolution modes are available for most sources. Webcams in particular tend to limit availble resolutions, so I have chosen the closest available that gives reasonable results. The RPi cannot handle the throughput of the higher resolutions from most sources.
I could spend weeks documenting all this, but the best thing to do is try it and see what works.
Re: Resolution
Post by g8gtz » Sun Feb 20, 2022 9:11 am
And then update the wiki so we can all learn!
