GB3TV
Locator: IO91RU
arthur21
GB3TV
Post by arthur21 » Tue Feb 08, 2022 1:04 pm
GB3TV is now in repeater mode.
The input frequency is 1249MHz for analogue input with 6MHz audio sub carrier .
The digital input is 1249MHz at 1000ks/s DVBS and MPEG2 4:3
Results locally have been good.
73 Arthur
G4CPE
Re: GB3TV
Post by g0mjw » Tue Feb 08, 2022 1:31 pm
That's good news. I will get out my QRP (3W) 23cms system and give it a try after work. I can generate more power, but hoping not to need it. I don't suppose there is any likelihood of a DVB-S2 upgrade? That would help. Do we need to set PIDs to anything unusual?
G4HTZ
Re: GB3TV
Post by G4HTZ » Wed Feb 09, 2022 6:32 pm
73 Arthur
G4CPE
Is it digital output now …what are the tx rx antennas and power ….used to receive it occasionally many years ago with a slight lift …but probably to far away in east Essex to receive it now at new qth
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
arthur21
Re: GB3TV
Post by arthur21 » Fri Feb 11, 2022 11:58 am
GB3TV is transmitting at 1ms/s DVBS and will only receive the same. The receiver is an old SL30/12 but appears to work well with the BATC recommended PID,s . Later in the year we hope to upgrade the TX modulator and receiver to DVBS2 .
We are recommending to our club members a cheap Satellite STB for reception of the 1ms/s transmission from GB3TV.
This STB is an Oakcastle SB200 purchased from AMAZON for just under £30.
73 G4CPE
Return to “GB3TV”
