portsdown 2020 and IQ FM modulator board
CU2ED
Post by CU2ED » Tue Dec 07, 2021 11:44 am
Hi all,
I have an old Portsdown unit with IQ modulator without any use as I removed the 7" LCD for my Portsdown 4 version, but thanks to this forum I found out a new 5" LCD compatible and very cheap at mouser, the problem is when I use the Portsdown 2020 version I can't see the IQ filter modulator available on the menu, as far I could read on batc wiki, it seems compatible ...
>> The following legacy features have been tested and work well:
>> DVB-S Transmissions using a BATC Filter-modulator board
So, for anyone using this old system, can you confirm that 2019 is the last version for the IQ board ?
Jacinto
cu2ed
Re: portsdown 2020 and IQ FM modulator board
Post by G8GKQ » Tue Dec 07, 2021 1:54 pm
Hi Jacinto
Are you sure that you have the Portsdown 2020 software? Maybe you have Portsdown 4 by mistake?
I have just tested the latest Portsdown 2020 software with a Filter Modulator board and it works perfectly. You do need to select "Portsdown" as the "Output to" device.
CU2ED
Post by CU2ED » Tue Dec 07, 2021 3:33 pm
This old unit has an RPI3B+ and later I instaled the 2019 and I have the "Porstdown" choice ...
I received the LCD yesterday and it was really late when I tried so I also could have done some mistakes, will try one more time when I get home, many thanks for testing and confirming it's working!!!
Jacinto, CU2ED
CU2ED
Post by CU2ED » Thu Dec 09, 2021 9:45 am
Yesterday I tested again Portsdown 2020 and as you said there is indeed the Portsdown choice and everything works OK ...
Sorry and thanks again ...
Jacinto
Cu2ed
